Cannot caluclate route concerning leg *number*
peter.detzner
Hi!
Right now I am struggeling probably with a small isse which drives me crazy.
I am trying to create a Route between 2 points, a starting point and the destination (Industriekai;24937;Flensburg;).
Everytime I am trying to calculate the Route I am receiving the error "cannot calculate route (concerning leg 1)".
How can I deal with this kind of problem resp. the address? In fact the routing is not possible for this address. Is there any option where I might "enable"?
My Routingoptions are:
parameter = RoutingParameter.OPTIMIZATION, value = "30"
parameter = RoutingParameter.ALLOW_SEGMENT_VIOLATIONS, value = "true"
ResultListOptions:
manoeuvres = false;
manoeuvreAttributes = false;
nodes = true;
polygon = true;
the Profile for the vehicle is truckfast".
Thanks for your help!
Peter
ResultListOptions:
manoeuvres = false;
nodes = true;
polygon = true;
Peter
Re: Cannot caluclate route concerning leg *number*
I beleive your issue is cause by local restriction on entering that part of the industrial area. Have a look at http://devblog.ptvgroup.com/2014/01/10/ ... -vehicles/ on information how to open up restricted area's.
peter.detzner
Thank you! The link solved my issue. Just changed the profile!
I'm having the same issue, using xServer Internet. Regrettably the link provided didn't solve this problem for me.
When I'm adding the code, I actually get another error, telling me that <Violations> must not be a child of <BasicDataRules>. From as far as I can tell <Violations> is on the same level as <BasicDataRules>, so they're actually both childs of <Course>?
I added all the rules to the XML but it seems to have no effect. What am I doing wrong? Here are the params for xRoute.calculateRoute:
"waypoints":
{"coords":[{"point":{"x":16.3492375,"y":48.254322}}],"linkType":"NEXT_SEGMENT"},
{"coords":[{"point":{"x":16.3136262,"y":48.220700}}],"linkType":"NEXT_SEGMENT","viaType":{"viaType":"VIA_STOP"}},
"options":
{"parameter":"OPTIMIZATION","value":90}
"exceptionPaths":null,
"details":
"polygon":true,
"boundingRectanglesC":1,
"boundingRectanglesOffset":300,
"totalRectangle":true
"callerContext":
"properties":
{"key":"Profile","value":"delivery"},
{"key":"CoordFormat","value":"OG_GEODECIMAL"},
{"key":"ResponseGeometry","value":"PLAIN"},
{"key":"ProfileXMLSnippet","value":"<Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xsi:noNamespaceSchemaLocation='http://localhost:50090/xtour/schema/XTourProfile.xsd'><Routing majorVersion=\"2\" minorVersion=\"0\"><Course><BasicDataRules><VehicleSpecific><DeliveryVehicles segmentMalus=\"2500\"/><EmergencyVehicles segmentMalus=\"2501\" turningBanCost=\"50000\"/><AuthorizedVehicles turningBanCost=\"50000\"/></VehicleSpecific></BasicDataRules><Violations><SegmentBlockingViolations enabled=\"true\" cost=\"50000\"/></Violations></Course><Vehicle><Legal><LegalCondition isAuthorized=\"true\" isDelivery=\"true\" isEmergency=\"true\" /></Legal></Vehicle></Routing></Profile>"}
}- Bernd Welter
Hello Gerhard,
the error message I get
https://xroute-eu-n-test.cloud.ptvgroup ... quest.html
Did you send the request to the proper method (calculateRoute) via JSON?
"errorMessage": "cannot calculate route (concerning leg 1)",
"errorKey": "2500",
"exceptionType": "com.ptvag.xserver.xroute.XRouteException"
}Did you send the request to the proper method (calculateRoute) via JSON?
yes, that's exactly the message that I'm getting, the same as mentioned by peter.detzner in the first post. I already implemented the fix according to the second post as you can see in my code example, but still getting the error.
Same happens btw for the GPS-position x: 15.0653484, y: 47.0596209 so we had this issue in several cases lately. It occurs when the last bit of the route to the destination is a pedestrian area or similar, I think.
I already tried FUZZY_LINKING ...
... but still getting the same error.
The documentation for linkType = NEXT_SEGMENT says
"waypoints":
{"coords":[{"point":{"x":16.3136262,"y":48.220700}}],"linkType":"FUZZY_LINKING","fuzzyRadius":250},
],The documentation for linkType = NEXT_SEGMENT says
How can I configure the link distance mentioned here?The waypoint has to be linked to the geographically nearest valid segment within the configured link distance. A segment is valid if it can be used by the configured vehicle type.
Hello Gerhard,
The linking distances are part of the node WAYPOINT:
I recommend to use AUTO_LINKING as the Linking Type for the Waypoints via the API / JSON.
PS:
Fuzzy linking is a mechanism that is only valid for inner waypoints (not start or end) because the target of FUZZY is to push a route on a specific area (e.g. standard route from Hamburg to Munich takes a track through West Germany and you'd like to push East Germany).
<Waypoint linkType="ROAD" maximumDistanceToCombinedTransport="100" maximumDistanceToSegment="1000">
<LinkTypeConfiguration>
<Road headingTolerance="360" maximumDistanceForNetworkClass0="1000" maximumNetworkClass="7" minimumNetworkClass="0" onlyReachableRoads="true"/>
<Smart checkNetworkClassOnlyForVias="true" maximumDistanceToMainNode="100" maximumDistanceToMainNodeForNetworkClass0="1500"/>
<TollStation maximumDistance="1000"/>
<RoadName maximumDistance="3000" maximumDistanceToMainNode="2000"/>
</LinkTypeConfiguration>
</Waypoint>Best regards,
PS:
thank you for the prompt and detailed explanation. Regrettably neither changing the linkType to AUTO_LINKING, nor the Waypoint XML-Code solved my problem.
Here's the code I tried (even changed the maximumDistance* vars from 100 to 1000):
Any suggestions on how to solve the issue?
Thanks again!
"waypoints":
{"coords":[{"point":{"x":16.3136262,"y":48.220700}}],"linkType":"AUTO_LINKING","viaType":{"viaType":"VIA_STOP"}},
"options":
"details":
"polygon":true,
"callerContext":
"properties":
{"key":"ProfileXMLSnippet","value":"<Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xsi:noNamespaceSchemaLocation='http://localhost:50090/xtour/schema/XTourProfile.xsd'><Routing majorVersion=\"2\" minorVersion=\"0\"><Waypoint linkType=\"ROAD\" maximumDistanceToCombinedTransport=\"1000\" maximumDistanceToSegment=\"1000\"><LinkTypeConfiguration><Road headingTolerance=\"360\" maximumDistanceForNetworkClass0=\"1000\" maximumNetworkClass=\"7\" minimumNetworkClass=\"0\" onlyReachableRoads=\"true\"/><Smart checkNetworkClassOnlyForVias=\"true\" maximumDistanceToMainNode=\"1000\" maximumDistanceToMainNodeForNetworkClass0=\"1500\"/><TollStation maximumDistance=\"1000\"/><RoadName maximumDistance=\"3000\" maximumDistanceToMainNode=\"2000\"/></LinkTypeConfiguration></Waypoint><Course><BasicDataRules><VehicleSpecific><DeliveryVehicles segmentMalus=\"2500\"/><EmergencyVehicles segmentMalus=\"2501\" turningBanCost=\"50000\"/><AuthorizedVehicles turningBanCost=\"50000\"/></VehicleSpecific></BasicDataRules><Violations><SegmentBlockingViolations enabled=\"true\" cost=\"50000\"/></Violations></Course><Vehicle><Legal><LegalCondition isAuthorized=\"true\" isDelivery=\"true\" isEmergency=\"true\" /></Legal></Vehicle></Routing></Profile>"}
}Thanks again!
No solution for this?
Hello again,
sorry, didn't have time for deeper analysis so far. From what I see there are two topics involved:
Could an error in the data cause this?
- the map you use - the behaviour does not occur in the same way with other maps
- the delivery flag: alternating this boolean parameter switches from error (isDelivery=true) and success (isDelivery=false)
<Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xsi:noNamespaceSchemaLocation='http://localhost:50090/xtour/schema/XTourProfile.xsd'> <Routing majorVersion="2" minorVersion="0"> <Vehicle> <Legal> <LegalCondition isAuthorized="false" isDelivery="true" isEmergency="false" /> </Legal> </Vehicle> </Routing> </Profile>
So here we go... though I can't provide a 100% solution I have new info about this (thanks to Frank for the analysis):
The area we are refering to seems to be restricted by so-called gates.
Let's start with some screenshots from an internal tool: But probably it is not a sufficient approach to enable this kind of flexibility.
So for now I can only explain the response.
If you set the deliveryFlag to false the linking favours a segment which can be reched without such problems: Does this help?
Bet regards,
Bet regards,
actually did the trick for us. Thank you very much, your support is really outstanding!!
<Course>
<Maneuver considerTurningBans="false" uTurnCost="5000"/>
</Course>- Bernd Welter
If you are happy with our work: tell our management.
If not: tell us
If not: tell us
I recently ran into a similar issues, I believe that these are are actually map errors. IMO the gates should have exceptions for the authorized flag. I' m checking this with our data department.
Hi Bernd
I'm facing the same error "Cannot calculate route concerning leg *number*" with the following address:
Rue de la Source 5
1020 Renens
https://goo.gl/maps/8dyJykFku9ZmCArSA
I have tried the suggestions:
https://xserver.ptvgroup.com/forum/post ... 552#pr1950
But none worked for me.
But, it works by changing the delivery flag: alternating this boolean parameter switches from error (isDelivery=true) and success (isDelivery=false)
Thank you in advance for your support.
Pedro Diogo
Rue de la Source 5
1020 Renens
Pedro Diogo
Hello Pedro,
looks like the road is forbidden in the TOMTOM data: In the HERE map it is a regular road. Maybe you can provide your exact XML request so we can reproduce and "tune" it?
Hi Bernd
Thank you for your fast reply.
Follows attached the XML request.
Pedro Diogo
Pedro Diogo
- Attachments
- xRouteRequest.XML
- (12.18 KiB) Downloaded 813 times
Hello Pedro,
here's the result of our development team's analysis:
Sorry for that output - sounds like this case needs a special manual treatment.
PS: I also want to emphasize that this isn't a but of the engine.
So while violations can help with a spcific category of restrictions this does not apply in your scenario.The violation concept does not help here as this is only valid for segment attributes like blockings. For geographic restrictions used here there is no possibility other than modifying them (e.g. including France to the allowed countries).
In this special case you can play around with the linking. If you set the link type of the second waypoint to "NEXT_NODE" than it works as the waypoint is linked a bit more east. Or you can "move" the waypoint a bit more away from the border. In any case you have to handle such waypoints manually.
Hi Bernd
It's clear now.
Thank you for your help.
Pedro Diogo
It's clear now.
Pedro Diogo
we also have a problem with the error message "cannot calculate route (concerning leg X)".
We have already tried a little bit with the parameters "isDelivery", "isAuthorized" and "isEmergency".
Generally we noticed that by setting these parameters more routes could be calculated. However, we also had a few cases where setting the "isEmergency" parameter resulted in an incorrect calculation.
Now we have a route where setting the "isDelivery" parameter leads to an error.
We have also tried setting "<Maneuver considerTurningBans="false" uTurnCost="5000"/>" which did not help.
I put the route and the XMLProfileSnippet in the attachment.
Can you help us to fix the problem?
With kind regards
Lennart Kampshoff
With kind regards
Lennart Kampshoff
