Cannot caluclate route concerning leg *number*
Hi!
Right now I am struggeling probably with a small isse which drives me crazy.
I am trying to create a Route between 2 points, a starting point and the destination (Industriekai;24937;Flensburg;).
Everytime I am trying to calculate the Route I am receiving the error "cannot calculate route (concerning leg 1)".
How can I deal with this kind of problem resp. the address? In fact the routing is not possible for this address. Is there any option where I might "enable"?
My Routingoptions are:
parameter = RoutingParameter.OPTIMIZATION, value = "30"
parameter = RoutingParameter.ALLOW_SEGMENT_VIOLATIONS, value = "true"
ResultListOptions:
manoeuvres = false;
manoeuvreAttributes = false;
nodes = true;
polygon = true;
the Profile for the vehicle is truckfast".
Thanks for your help!
Peter
ResultListOptions:
manoeuvres = false;
nodes = true;
polygon = true;
Peter
Re: Cannot caluclate route concerning leg *number*
I beleive your issue is cause by local restriction on entering that part of the industrial area. Have a look at http://devblog.ptvgroup.com/2014/01/10/ ... -vehicles/ on information how to open up restricted area's.
Thank you! The link solved my issue. Just changed the profile!
I'm having the same issue, using xServer Internet. Regrettably the link provided didn't solve this problem for me.
When I'm adding the code, I actually get another error, telling me that <Violations> must not be a child of <BasicDataRules>. From as far as I can tell <Violations> is on the same level as <BasicDataRules>, so they're actually both childs of <Course>?
I added all the rules to the XML but it seems to have no effect. What am I doing wrong? Here are the params for xRoute.calculateRoute:
"waypoints":
{"coords":[{"point":{"x":16.3492375,"y":48.254322}}],"linkType":"NEXT_SEGMENT"},
{"coords":[{"point":{"x":16.3136262,"y":48.220700}}],"linkType":"NEXT_SEGMENT","viaType":{"viaType":"VIA_STOP"}},
"options":
{"parameter":"OPTIMIZATION","value":90}
"exceptionPaths":null,
"details":
"polygon":true,
"boundingRectanglesC":1,
"boundingRectanglesOffset":300,
"totalRectangle":true
"callerContext":
"properties":
{"key":"Profile","value":"delivery"},
{"key":"CoordFormat","value":"OG_GEODECIMAL"},
{"key":"ResponseGeometry","value":"PLAIN"},
{"key":"ProfileXMLSnippet","value":"<Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xsi:noNamespaceSchemaLocation='http://localhost:50090/xtour/schema/XTourProfile.xsd'><Routing majorVersion=\"2\" minorVersion=\"0\"><Course><BasicDataRules><VehicleSpecific><DeliveryVehicles segmentMalus=\"2500\"/><EmergencyVehicles segmentMalus=\"2501\" turningBanCost=\"50000\"/><AuthorizedVehicles turningBanCost=\"50000\"/></VehicleSpecific></BasicDataRules><Violations><SegmentBlockingViolations enabled=\"true\" cost=\"50000\"/></Violations></Course><Vehicle><Legal><LegalCondition isAuthorized=\"true\" isDelivery=\"true\" isEmergency=\"true\" /></Legal></Vehicle></Routing></Profile>"}
Hello Gerhard,
the error message I get
https://xroute-eu-n-test.cloud.ptvgroup ... quest.html
Did you send the request to the proper method (calculateRoute) via JSON?
"errorMessage": "cannot calculate route (concerning leg 1)",
"errorKey": "2500",
"exceptionType": "com.ptvag.xserver.xroute.XRouteException"
yes, that's exactly the message that I'm getting, the same as mentioned by peter.detzner in the first post. I already implemented the fix according to the second post as you can see in my code example, but still getting the error.
Same happens btw for the GPS-position x: 15.0653484, y: 47.0596209 so we had this issue in several cases lately. It occurs when the last bit of the route to the destination is a pedestrian area or similar, I think.
I already tried FUZZY_LINKING ...
... but still getting the same error.
The documentation for linkType = NEXT_SEGMENT says
"waypoints":
{"coords":[{"point":{"x":16.3136262,"y":48.220700}}],"linkType":"FUZZY_LINKING","fuzzyRadius":250},
How can I configure the link distance mentioned here?The waypoint has to be linked to the geographically nearest valid segment within the configured link distance. A segment is valid if it can be used by the configured vehicle type.
Hello Gerhard,
The linking distances are part of the node WAYPOINT:
I recommend to use AUTO_LINKING as the Linking Type for the Waypoints via the API / JSON.
PS:
Fuzzy linking is a mechanism that is only valid for inner waypoints (not start or end) because the target of FUZZY is to push a route on a specific area (e.g. standard route from Hamburg to Munich takes a track through West Germany and you'd like to push East Germany).
<Waypoint linkType="ROAD" maximumDistanceToCombinedTransport="100" maximumDistanceToSegment="1000">
<LinkTypeConfiguration>
<Road headingTolerance="360" maximumDistanceForNetworkClass0="1000" maximumNetworkClass="7" minimumNetworkClass="0" onlyReachableRoads="true"/>
<Smart checkNetworkClassOnlyForVias="true" maximumDistanceToMainNode="100" maximumDistanceToMainNodeForNetworkClass0="1500"/>
<TollStation maximumDistance="1000"/>
<RoadName maximumDistance="3000" maximumDistanceToMainNode="2000"/>
</LinkTypeConfiguration>
</Waypoint>
PS:
thank you for the prompt and detailed explanation. Regrettably neither changing the linkType to AUTO_LINKING, nor the Waypoint XML-Code solved my problem.
Here's the code I tried (even changed the maximumDistance* vars from 100 to 1000):
Any suggestions on how to solve the issue?
Thanks again!
"waypoints":
{"coords":[{"point":{"x":16.3136262,"y":48.220700}}],"linkType":"AUTO_LINKING","viaType":{"viaType":"VIA_STOP"}},
"options":
"details":
"polygon":true,
"callerContext":
"properties":
{"key":"ProfileXMLSnippet","value":"<Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xsi:noNamespaceSchemaLocation='http://localhost:50090/xtour/schema/XTourProfile.xsd'><Routing majorVersion=\"2\" minorVersion=\"0\"><Waypoint linkType=\"ROAD\" maximumDistanceToCombinedTransport=\"1000\" maximumDistanceToSegment=\"1000\"><LinkTypeConfiguration><Road headingTolerance=\"360\" maximumDistanceForNetworkClass0=\"1000\" maximumNetworkClass=\"7\" minimumNetworkClass=\"0\" onlyReachableRoads=\"true\"/><Smart checkNetworkClassOnlyForVias=\"true\" maximumDistanceToMainNode=\"1000\" maximumDistanceToMainNodeForNetworkClass0=\"1500\"/><TollStation maximumDistance=\"1000\"/><RoadName maximumDistance=\"3000\" maximumDistanceToMainNode=\"2000\"/></LinkTypeConfiguration></Waypoint><Course><BasicDataRules><VehicleSpecific><DeliveryVehicles segmentMalus=\"2500\"/><EmergencyVehicles segmentMalus=\"2501\" turningBanCost=\"50000\"/><AuthorizedVehicles turningBanCost=\"50000\"/></VehicleSpecific></BasicDataRules><Violations><SegmentBlockingViolations enabled=\"true\" cost=\"50000\"/></Violations></Course><Vehicle><Legal><LegalCondition isAuthorized=\"true\" isDelivery=\"true\" isEmergency=\"true\" /></Legal></Vehicle></Routing></Profile>"}
Thanks again!
No solution for this?
Hello again,
sorry, didn't have time for deeper analysis so far. From what I see there are two topics involved:
Could an error in the data cause this?
- the map you use - the behaviour does not occur in the same way with other maps
- the delivery flag: alternating this boolean parameter switches from error (isDelivery=true) and success (isDelivery=false)
<Profile xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xsi:noNamespaceSchemaLocation='http://localhost:50090/xtour/schema/XTourProfile.xsd'> <Routing majorVersion="2" minorVersion="0"> <Vehicle> <Legal> <LegalCondition isAuthorized="false" isDelivery="true" isEmergency="false" /> </Legal> </Vehicle> </Routing> </Profile>
