I am looking into optimizing several orders for CZ.
Here is a quick overview of 5 customers, the stop symbol is the 5th customer:
There is a special requirement: Customers which are located near each other (same postal code ares) should be planned together.
In this example: Postal codes starting with 2 is one group, starting with 7 is another group etc.
There should be no tour driving from east to west inside the country. I saw your forum post viewtopic.php?t=1859
I am curious: Is clustering something that can be used together with xTour? Or do you have another idea how to achive this?
Attached is the request and response that I am currently getting.
The response gives me 3 tours.
Tour 1 is a FTL this is ok.
Tour 3 is not ok - driving from east to west - it looks like this:
I already tried setting AvoidIntersections to true but this does not help here.
Geographical grouping - PTV xServer 2 - xTour
- Attachments
- request.txt
- (15.5 KiB) Downloaded 1799 times
- response.txt
- (60.6 KiB) Downloaded 1820 times
Re: Geographical grouping - PTV xServer 2 - xTour
Hi Matthias,
the main purpose of the cluster component is
I need some time to look into this, so please stay patient.
- to determine the groups from a strategic level based on "fair distribution within the clusters" (based on huge workloads)
- and then use the additional group IDs in multiple, distinct operational plannings (e.g. during the next business year). Check this story as an example.
- The separation of strategic and operational planning used to be the solution for planning stories with a complexity where the operational components were not able to handle the big scenario. SInce Optiflow is able to handle many thousand orders in a single planning the need for clustering has at least decreased: some customers who were used to perform the 2 step approach (xCluster2+xTour2) are now solving their daily tour plannings with Optiflow in a single step.
- If you apply a "zip code based" grouping this is understandeable at first - but doesn't reflect the absolute workload in the virtual areas.
