List of optimizations running under my token...
I'd like to know what optimization tasks are currently in progress under my token's responsibility.
As far as I knwo there's no "list" method available as of 21.12.2023, right?
My sample application therefore executes a "garbage collection" when the program terminates because after the program exits it will definetly not retrieve the results anymore.
michael.unrau
Re: List of optimizations running under my token...
Post by michael.unrau »
Yes, at the moment there is no possibility to list running/finished jobs, so you have to keep track of started optimizations yourself.
Cheers,
Michael
Michael Unrau
DevOps Engineer
that's at least very important and I look forward to some "administration" methods. Otherwise I probably run into this message
  "ErrorCode": 403,
  "ErrorContent": "{\"description\":\"A product-specific restriction is exceeded.\",\"errorCode\":\"ROUTEOPTIMIZATION_RESTRICTION_EXCEEDED\",\"causes\":[{\"description\":\"The maximum number of concurrent optimizations is exceeded.\",\"errorCode\":\"ROUTEOPTIMIZATION_NUMBER_OF_OPTIMIZATIONS_EXCEEDED\",\"details\":{\"limit\":1}}]}",
  "Headers": {
    "Ratelimit-Remaining": [
      "8"
  "Message": "Error calling StartOptimization: {\"description\":\"A product-specific restriction is exceeded.\",\"errorCode\":\"ROUTEOPTIMIZATION_RESTRICTION_EXCEEDED\",\"causes\":[{\"description\":\"The maximum number of concurrent optimizations is exceeded.\",\"errorCode\":\"ROUTEOPTIMIZATION_NUMBER_OF_OPTIMIZATIONS_EXCEEDED\",\"details\":{\"limit\":1}}]}",
  "Data": {},
  "InnerException": null,
...  "HelpLink": null,
  "Source": "PTV_Developer",
  "HResult": -2146233088
So in my current test client I store the UUID of a planning right after the startOptimization and when I have to terminate the application - for whatever reason - I desperately execute a "stopOptimization" because I won't be able to fetch the result anyway.
Also check this new feature!
viewtopic.php?p=5417#p5417
SInce version 1.22.0 and 1.23.0 it is now possible to
  • ...look into your existing plannings that are still running or have been processed in the recent days (listOptimizations):
  • ...retrieve requests and results from this cache (getOptimizationRequest / getOptimizationResult)
  • ...monitor the progress of recent plannings (getOptimizationProgress)
