List of optimizations running under my token...
Questions refering to the Optiflow based API within PTV Developer (launched on 20.12.2023)
I'd like to know what optimization tasks are currently in progress under my token's responsibility.
As far as I knwo there's no "list" method available as of 21.12.2023, right?
My sample application therefore executes a "garbage collection" when the program terminates because after the program exits it will definetly not retrieve the results anymore.
michael.unrau
Re: List of optimizations running under my token...
Post by michael.unrau »
Yes, at the moment there is no possibility to list running/finished jobs, so you have to keep track of started optimizations yourself.
Cheers,
Michael
Michael Unrau
DevOps Engineer
that's at least very important and I look forward to some "administration" methods. Otherwise I probably run into this message
  "ErrorCode": 403,
  "ErrorContent": "{\"description\":\"A product-specific restriction is exceeded.\",\"errorCode\":\"ROUTEOPTIMIZATION_RESTRICTION_EXCEEDED\",\"causes\":[{\"description\":\"The maximum number of concurrent optimizations is exceeded.\",\"errorCode\":\"ROUTEOPTIMIZATION_NUMBER_OF_OPTIMIZATIONS_EXCEEDED\",\"details\":{\"limit\":1}}]}",
  "Headers": {
    "Ratelimit-Remaining": [
      "8"
  "Message": "Error calling StartOptimization: {\"description\":\"A product-specific restriction is exceeded.\",\"errorCode\":\"ROUTEOPTIMIZATION_RESTRICTION_EXCEEDED\",\"causes\":[{\"description\":\"The maximum number of concurrent optimizations is exceeded.\",\"errorCode\":\"ROUTEOPTIMIZATION_NUMBER_OF_OPTIMIZATIONS_EXCEEDED\",\"details\":{\"limit\":1}}]}",
  "Data": {},
  "InnerException": null,
...  "HelpLink": null,
  "Source": "PTV_Developer",
  "HResult": -2146233088
So in my current test client I store the UUID of a planning right after the startOptimization and when I have to terminate the application - for whatever reason - I desperately execute a "stopOptimization" because I won't be able to fetch the result anyway.
Also check this new feature!
viewtopic.php?p=5417#p5417
SInce version 1.22.0 and 1.23.0 it is now possible to
  • ...look into your existing plannings that are still running or have been processed in the recent days (listOptimizations):
  • ...retrieve requests and results from this cache (getOptimizationRequest / getOptimizationResult)
  • ...monitor the progress of recent plannings (getOptimizationProgress)
