Routing with ferries
Tomasz Lotocki
Post by Tomasz Lotocki »
We have a following question from one of our Partners:
I am looking for the most optimal solution using the PTV xServer API, which would reflect the functionality of PTV Map&Guide indicating alternative ferries on the route at selected points. The scenario is as follows:
1. The client provides the coordinates of the starting point A and ending point B, for which I get the route using the calculateRoute endpoint from xRoute.
2. The customer selects a point on this route (we assume that it runs partly by water) for which he would like to receive alternative ferries that could potentially be used to get to the end point B (exactly as in PTV Map&Guide - ppm on map > find ferries).
3. The last step would be for the customer to select one of the proposed ferries and change the course of the original route so that it led from A to B via the newly selected ferry.
How can we assist here?
Tomasz Lotocki
Sales
PTV Logistics - Poland
Re: Routing with ferries
Hi Tomasz,
sounds like you need the following information:
  • We support a so-called com.ptvgroup.xserver.xroute.CombinedTransportViaWaypoint, which is a dedicated ferry connection from one unique start port to a unique destination port. To define such a waypoint you need to provide the combinedTransportId
  • To gather the combinedTransportId you can use the com.ptvgroup.xserver.xdata.SegmentsRequest which enables you to search for such an ID:
  • The search could be based on various approaches:
  • For the SegmentOptions you need to search for SegmentType.COMBINED_TRANSPORT
  • This is a nearest search in the region of Kiel
    • Code: Select all
        "$type": "SegmentsByCoordinateRequest",
        "segmentsOptions": {
          "includedSegmentTypes":["COMBINED_TRANSPORT"]
        "resultFields": {
          "polyline": true,
          "descriptors": true
        "coordinate": {
          "x": 10.132240358,
          "y": 54.323249814
    • Response
        "$type": "SegmentsResponse",
        "segments": [
            "type": "COMBINED_TRANSPORT",
            "polyline": {
              "plain": {
                "$type": "Polyline",
                "polyline": [
                    "x": 10.140115155,
                    "y": 54.319672521
                    "x": 11.914234093,
                    "y": 57.695938264
            "id": "SEGM00028f61c441v6PFAeoSAeY72m4SlWvidQL9G/oVRsIYzlEa0BvMbh6Za+J5RbckwFUGxgSYGQj2LM1uKKxo8nVatAr+AkfQAI0YCPZlh1M0zS3lRTnjHNtnG6NmhjIe2C7wNUTtf/s="
  • And here comes the routring request
        "waypoints": [
            "$type": "OnRoadWaypoint",
            "location": {
            "coordinate": {
              "x": 10.132240358,
              "y": 54.323249814
            "considerAlternativeNearByRoads": false
          "$type": "CombinedTransportViaWaypoint",
          "combinedTransportId": "SEGM00028f61c441v6PFAeoSAeY72m4SlWvidQL9G/oVRsIYzlEa0BvMbh6Za+J5RbckwFUGxgSYGQj2LM1uKKxo8nVatAr+AkfQAI0YCPZlh1M0zS3lRTnjHNtnG6NmhjIe2C7wNUTtf/s="
          "location": {
            "coordinate": {
              "x": 12.567560214,
              "y": 55.67567061
      "resultFields": {
        "polyline": true
:idea: Keep this in mind:
  • SegmentIDs can change from map to map version!
Here's just one more screenshot from my sample application.
It demonstrated the potential outpout of the "ferry search dialog".
Rectangle based search... returns all ferries that depart from a coordinate within the rectangle...
Another example requested by a partner:
  • from Hook van Holland
  • to Killingholme
