we have two requirements in context of routing through Kosovo but I think it's a general topic which can be extend to other areas, too.
1. We have a route with two stations - both in Serbia. If the stations are close to the border of Kosovo the result route can go through Kosovo. We would like to avoid this because if a part of the route goes through Kosovo, there are some additional requirements by law. Normally, we can force the routing to avoid a country by setting the allowedCountry or prohibitedCountries on RouteOptions.GeographicRestrictions.In case of Kosovo it is not possible because of the country code. For details see https://xserver.ptvgroup.com/forum/view ... 4269#p4269
Is there any other way to exclude the Kosovo from the routing? We search for a solution for the xServer Internet.
2. If we have a route with some stations in Serbia and only one station in Kosovo, we can not use the solution for 1. to ensure we have as little as possible parts in Kosovo. Our idea is to restrict the border access, to force the routing only take the border if neccessary to reach a station.
Is there any way to force the routing to avoid borders if possible? Maybe by setting a malus?
Regards
Christopher
xRoute2: Restrict routes through Kosovo (start in Serbia)
Re: xRoute2: Restrict routes through Kosovo (start in Serbia
Hello Christopher,
quite often the blocking of a country is achieved with the simple "prohibited countries" parameter in xRoute2. This refers to so-called "integration units" such as Germany, Austria, Serbia,...
In your case the "country" KOSOVO isn't a technical integration unit (and I don't even want to discuss political states here in the forum).
On a meta level we offer mechanisms to prevent users from driving into certain areas. E.g. it is possible to block all segment lines that connect the outside with the critical area. In the case of cosovo: there are about 30-40 road segments that connect "the KOSOVO" with adjacent areas such as Albania, Serbia, ...
Blocking the entrances does not prevent you from routing within KOSOVO!
If you know the IDs of these segments for a specific map version you may use the "custom feature layer" approach which requires you to have access to an xServer 2 with the required map and a license that supports "xData.createFeatureLayer".
If these ingredients are available you could send a "xData.createFeatureLayer" call.
Check this overview of available segment attributes.
Segment IDs depend on map versions!
Response incl. the binary feature layer:
- Approach #1 - create a so-called BINARY FEATURE layer (relevant for XSI):
Consume the string and inject it into the routing request as routing option.
"resultFields": { "binaryFeatureLayer": true } - Approach #2 - create a persisted feature layer scenario
In this case also provide a "scenario id" (e.g. "myScenario"). This will create content on the used server and you can activate the RequestBase.RequestProfile.FeatureLayerProfile by specifying the scenario "myScenario"" in the routing request. This approach doesn't work in XSERVER INTERNET because you can't create layers over there (as of 17.12.2021).
"resultFields": { "binaryFeatureLayer": false }
- "key": "opening","value": "0" : selected segments are blocked
- "key": "note","value": "Bullshitbingo" : adds a note to a segment
- "key": "maxLength","value": "666" : defines a length restriction
"$type": "CreateFeatureLayerRequest",
"scope": "globalscope",
"storedProfile": "default",
"themeId": "PTV_RoadAttributes",
"features": [
"segmentIds": [
"SEGM0002e13e9d39v6PFAet8NNgA+2wyzBP+aDPJB+9QPQ==",
"SEGM0002cbea70e0v6PFAet8NNgA+2wzzxD6Zj7ACOt0LMkZ9WM+zxP7YC7aIvs=",
"SEGM000243be42adv6PFAet8NNgA+2wzzxb7ajDOA+9QPQ==",
"SEGM000258934b61v6PFAet8NNgA+2wyyBbzbT3JAOt0LMkZ9GU6wRj7Zy/ZAepkNcYR+WI6yxDtdSzYEfNrPssR/GA52QLIZA==",
"SEGM000220faab77v6PFAet8NNgA+2wyyBbzbT3KA+xTPQ==",
"SEGM00022cdad6e7v6PFAet8NNgA+2wzzxb7ajPKBO1yLMkZ9WI6yR/1ZCvYEcpk",
"SEGM0002ed368724v6PFAet8NNgA+2wzzxb7ajPJB+pmDsk=",
"SEGM0002632198b0v6PFAet8NNgA+2wzzxb7ajPJB+hXPQ==",
"SEGM0002d59a13a9v6PFAet8NNgA+2w8wRDyZDfDCeh3LMkZ+mw8wBHxbyTZIfs=",
"SEGM000297c9cac3v6PFAet8NNgA+2w8whb5ZzjNBep1LMkZ+mg4yhP/YC3ZAepkNcgd/mc/zRTqdC3YEfNlMcoR+WY93gHLZA==",
"SEGM00022abb5f39v6PFAet8NNgA+GY9zRH8YTjLAONcPQ==",
"SEGM00028c45650dv6PFAet8NNgA+GY8zBzwZzXDAu9QPQ==",
"SEGM00021ba0387av6PFAet8NNgA+GY8zhX6ZTrKB+pVPQ==",
"SEGM00029c144b9fv6PFAet8NNgA+GY+yBX8YzjLAOxzLMoT+GU5zhb+ZS/aAupnP8oR+mE7zh/jdA3J",
"SEGM00028ddde8b6v6PFAet8NNgA+GY+yxn0YjTFBOpjC8k=",
"SEGM0002e64c52d4v6PFAet8NNgA+GY/whH7aT7HCOt0LMoT+W89yRz3bC3aIvs=",
"SEGM0002a008f580v6PFAet8NNgA+GY/zBX/YD3KAel2LMoT+WE5zRX7ZizaIvs=",
"SEGM0002facfef16v6PFAet8NNgA+GY/yRT0aT7GCOxTPQ==",
"SEGM0002e5ba0d5dv6PFAet8NNgA+GY/yhT4ZzHDA+hXPQ==",
"SEGM0002ae47ae39v6PFAet8NNgA+GY8zxP6YjnGCOt0LMoT+mI/yBf+Yy3ZAepnP8gW9WQyzRbvdT/6EQ==",
"SEGM000299ac043cv6PFAet8NNgA+GY9wRr+ZT7ECOt0LMoT+2M9zxL4Zi7dJfs=",
"SEGM0002bbc1b01bv6PFAet8NNgA+GY9yBH/aTDJBOtUPQ==",
"SEGM0002218d7a93v6PFAet8NNgA+2wyyBb8ajLKBOt0LMkZ9GQ/zxf9byTZIfs=",
"SEGM0002a854f4a8v6PFAet8NNgA+2wyzBP+ZzzIBupmDsk=",
"SEGM0002084ba613v6PFAet8NNgA+2wwyxD6Zj3OAupVPQ==",
"SEGM0002f3c48bebv6PFAetxPdwA+2wwzhb3azvACepVPQ==",
"SEGM00021f6b816ev6PFAet8NNgA+2wwzhb3azvACe1SPQ=="
"direction": "BOTH",
"descriptions": [
"attributes": [
"key": "opening",
"value": "0"
"key": "note",
"key": "maxLength",
"value": "666"
"resultFields": {
}Code: Select all
"$type": "FeatureLayerResponse",
"binaryFeatureLayer": "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",
"featureLayerDescription": {
"size": 43612,
"providerInformation": "HERE 2021.q2"
}Bernd Welter
Spoiler Alert:
IN v2.26 we will offer an new Geographic Restriction property prohibitedSegmentsByIntersectingPolylines: This will also work in xServer internet... and DIMA...!
Re: xRoute2: Restrict routes through Kosovo (start in Serbia)
HI there,
In the meantime I added the com.ptvgroup.xserver.routing.GeographicRestrictions.prohibitedSegmentsByIntersectingPolylines to my testclient. Here's some footage based on the KOSOVO polyline: The sample polyline I gathered was originally based on about 20'000 points which is too much for the API, so I used only every 10th coordinate.
Best regards,If these polylines intersect more than 5000 segments, the request is rejected with an exception.
- Attachments
- reduced-kosovo-5000.txt
- the linestring I used - source OSM, no guarantee, usage at own risk
- (81.43 KiB) Downloaded 331 times
Some news in this context:
- Starting with then Map 2026.2 HERE the area of the Kosovo is getting the inofficial, technical countrycode "XK"
- Based on this it is then possible to identify trespassing this area and to avoid the region via the well known "prohibitedCountries" feature
- Geocoding is in progress: xLocate2.40 returns the code, but does not yet consider the ""allowedCountries" with the code properly (coming soon)
- 4.5.2026: Already in effect on my local xServer2 - about to come on Developer soon
