Routing options to use motorways and ferries
Uwe Schuster
Post by Uwe Schuster »
We are migrating from Mapserver to xServer 2 and routing with details like profiles, toll and emission does work. There are some remaining questions and one of them is regarding some routing profile options.
Our option (bool)Mapserver xServer 2
[x] Use motorway IRouteOptions2::put_RouteWithoutAutoroute(section, [true|false])
Mapserver SDK documentation:
"For the VARIANT_TRUE value the use of motorways is not permitted."
Use penaltiesByNetworkClass? NC0? Which penalty?
[x] Use residential roadsIDrivingOptions_5_4_0_0::put_ResidentsOnlyFactor(section, factor)
"factor Modifier for streets that are restricted to residents"
"The values range from -99 (strong preference) to 0 (normal rating) to 2500 (strong avoidance). 2501 can be used to block streets that are restricted to residents completely. "
We do use the default value (0) when the option is checked and 2500 when the option is not checked.
Use penaltiesByNetworkClass? Which NC?
[x] Use ferriesIDrivingOptions_5_4_0_0::put_FerryFactor(section, factor)
"Modifier for ferries."
"The values range from -99 (strong preference) to 0 (normal rating) to 2500 (strong avoidance). 2501 can be used to block ferries completely."
We do use 0 when the option is checked and 2500 when the option is not checked.
Use boatPenalty?
[x] Use motorway
	"routingProfile": {
		"course": {
			"network": {
				"penaltiesByNetworkClass": {
					"penalties": [
						THIS_VALUE_HERE_QUESTIONMARK,
						10,
						15,
						35,
						40,
						90,
						100,
						100
Is this correct to use routingProfile::course::network::penaltiesByNetworkClass::penalties?
"[x] Use motorway" = 0 for the first network class
"[ ] Use motorway" = 2500 for the first network class
Is this correct to use routingProfile::course::network::penaltiesByNetworkClass::penalties as well? What is the network class for this case?
[x] Use ferries
	"routingProfile": {
		"course": {
			"combinedTransport": {
				"boatPenalty": "THIS_VALUE_HERE_QUESTIONMARK"
Is this correct to use routingProfile::course::combinedTransport::boatPenalty?
"[x] Use ferries" = 0
"[ ] Use ferries" = 2500
Uwe Schuster
C-Informationssysteme GmbH
Re: Routing options to use motorways and ferries
Hi Mr Schuster,
afaik Avoid_Highways refers to NC0 AND NC1.
Residentials is NC5.
I'll cross check this with DEV!
But I think you are on a proper path,
definition of network classes. Taken from xserver 1 documentation
About "IDrivingOptions_5_4_0_0::put_ResidentsOnlyFactor"
That is found at:
Routing / Course / BasicDataRules / SpecialAreas / @residentialMalus (xServer 1 profile)
RequestBase.requestProfile.routingProfile.crourse.apecialAreas.residentsOnlyPenalty (xServer 2 request)
It is not connected to a specific road type (== network class) but to a segment attribute. The attributes indicates that access to the road is only allowed for people who are resident.
Uwe Schuster
Thanks Bernd and Joost!
For me "course::specialAreas::residentsOnlyPenalty" sounds more reasonable as equivalent for "IDrivingOptions_5_4_0_0::put_ResidentsOnlyFactor". I will try that (as soon as I remember a test case for that).
Uwe Schuster
