How to display emission zones in xMap2?
PTV Developer Raster Maps API
Lauterfeld
Post by Lauterfeld »
Our users are missing the visualization of emission zones in xMap2. Worked fine in xMap1. How can we achieve the visualization of these zones?
Volker
Volker Lauterfeld
Software-Entwicklung und Projekte
COS GmbH
Gesellschaft für Computersysteme,
Organisation und Softwareentwicklung mbH
Raiffeisenstraße 21
D-77704 Oberkirch
http://www.cosonline.de/
Re: How to display emission zones in xMap2?
Hello Volker,
copy the two attached files in your /conf/profiles folder and use the "storedProfile=emissionzones".
emissionzones.xml
stored profile
(261 Bytes) Downloaded 3690 times
emissionzones.ini
referenced render profile
(40.52 KiB) Downloaded 3661 times
If you want to play with the ALPHA blendings you can update these keys:
[config.background.alphablending]
; Green Zone, green
29=72
; Green Zone, yellow
30=72
; Green Zone, red
31=72
Result:
based on alpha blending = 36
Here's the sample request:
  "storedProfile" : "emissionzones",
  "mapSection": {
    "$type": "MapSectionByCenter",
    "centerCoordinate": {
      "x": 8.4746598928 ,
      "y": 49.004840798
    "zoom": 10
  "imageOptions": {
    "width": 800,
    "height": 600
#greenzones #emissionzones
I've been asked whether it is possible to request a layer that only contains the greenzones.
Here we are - OnPremise only!
Copy both files into your local /xserver.../conf/profiles and request this example
produced by the sample above
emissionzonesNotVisible.ini
the INI file that surpressed any other content but emission zones
(42.29 KiB) Downloaded 3279 times
emissionzonesNotVisible.xml
The xServer stored profile that refers to the INI file
(308 Bytes) Downloaded 3429 times
by the way:
As mentioned in the xServer 2.30 release announcement we will offer a new technical approach to visualize Low Emission Zones through xMap2...
