Schiersteiner Brücke - how to deal with construction sites?
Hello together,
I've been asked how to deal with traffic construction sites that are not part of our map data, e.g. with the famous "Schiersteiner Brücke" https://de.wikipedia.org/wiki/Schiersteiner_Br%C3%BCcke that links Wiesbaden-Schierstein with Mainz-Mombach.
PS: Please feel free to add further objects (official tunnel names, bridges, ...) in replies so we can make them searcheable ;-)
Well, there are several potrential strategies available to deal with such issues. A quick forum posting can't replace the documentation but maybe I can give you some hints and you can evaluate whether one of them fits your current challenge.
  • Approach #1 (quick and dirty): use an ExceptionPath object to malify the bridge and identify it by the street name:
    <ArrayOfExceptionPath_3>
    <ExceptionPath absTimeMalus="0" binaryPathDesc="" extSegments="" relMalus="2501" street="Schiersteiner Br?xmlns="http://xroute.xserver.ptvag.com">
    <wrappedNodes xsi:nil="true" />
    <polyline xsi:nil="true" />
    </ExceptionPath>
    </ArrayOfExceptionPath_3>
    This approach requires you to identify the object within the request which works fine for this bridge because of the street name. It might be more difficult to reference other objects,
    The left map shows the result of the routing based on the ExceptionPath with streetname=&quot;Schiersteiner Brücke&quot; and RelMalus=&quot;2501&quot;: the bridge is avoided and the track takes a large detour.
    The left map shows the result of the routing based on the ExceptionPath with streetname="Schiersteiner Brücke" and RelMalus="2501": the bridge is avoided and the track takes a large detour.
  • Approach #1b: precalculate a BinaryPathDescription of a street section which you want to block (e.g. if you want to block just a subsection of a specific highway but not the whole A123). Just use the BinaryPath instead of the StreetName, but still work with ExceptionPath and RelMalus=2501.
  • Approach #2 (less quick, much more effort): use the RoadEditor of Map&Guide Desktop: block the street in both directions and create a binary truckattributes file which can be used in the xRoute:
    <RoutingOption parameter="ROADEDITOR_LAYERNAME" value="SchiersteinerBr?xmlns="http://xroute.xserver.ptvag.com" />
    <RoutingOption parameter="ENABLE_ROADEDITOR" value="True" xmlns="http://xroute.xserver.ptvag.com" />
    This is how the RoadEditor looks like in Map&amp;Guide Desktop. I blocked the two directions and exported the data into a binary layer file. Afterwards I copied the file into my map folder/RE and referenced it during the routing call.
    This is how the RoadEditor looks like in Map&Guide Desktop. I blocked the two directions and exported the data into a binary layer file. Afterwards I copied the file into my map folder/RE and referenced it during the routing call.
  • For those who have proper access to a direct RoadEditor database you can also use the database approach.
Here are some screenshots... Have fun!
PS: mercator coordinates of sample route:
914068/6447331 => 912599/6443504
Re: Schiersteiner Brücke - how to deal with construction sit
And another Example which works fine with ExceptionPath+StreetName+RelMalus:
  • Leverkusener Brücke
    Leverkusener Brücke
Another important info:
The Leverkusener Brücke is blocked for trucks exceeding MAX_WEIGHT=3500.
So this is a conditional blocking and requires RoadEditor (or you have to decide about which ExceptionPaths you need for the current routing).
RoadEditor attributes MAX_WEIGHT used. This truck weighs 666 kilograms and is therefore allowed to use the bridge.
And this truck weighs 6666kg and exceeds the MAX_WEIGHT so it has to perform a detour.
And here we go : another challenge is the so-called WARNOW Tunnel near Rostock.
Some customers want to avoid this tunnel because it raises toll lof type SPECIALCHARGETUNNEL.
https://de.wikipedia.org/wiki/Warnowtunnel
comparison of tracks with and without the tunnel. I used the simple EXCEPTIONPATH approach with streetname and relmalus for this blocking.
I've been asked for some lines of code... here we are... C# rules.
I created a single element of type ExceptionPath based on the streetname.
The "Schiersteiner Brücke" is blocked due to the malus=2501.
The relevant part starts in line #49:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using XServer;
namespace RoutingBeispiel
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
            XRouteWSService svcRoute = new XRouteWSService();
            WaypointDesc wpdStart = new WaypointDesc()
                linkType = LinkType.AUTO_LINKING,
                wrappedCoords = new XServer.Point[] {
                    new XServer.Point() {
                        point = new PlainPoint() {
                            x = 913800,
                            y = 6447494
            WaypointDesc wpdDestination = new WaypointDesc()
                            x = 913407,
                            y = 6443915
            WaypointDesc[] wpdStationlist = new WaypointDesc[] {
                wpdStart,
                wpdDestination
            ExceptionPath exSchiersteinerBridge = new ExceptionPath() {
                relMalus = 2501,
                street = "Schiersteiner Brücke"
            ExceptionPath[] arrExceptionPaths = new ExceptionPath[] {
            RouteInfo routeNoPath = svcRoute.calculateRouteInfo(wpdStationlist, null, null, null);
            RouteInfo routeWithPath = svcRoute.calculateRouteInfo(wpdStationlist, null, arrExceptionPaths, null);
Here is another example: the LONDON BRIDGE
Left map: using the LONDON BRIDGE is possible - there is no INTERSECTING LINE defined.<br />Right map: crossing the bridge is forbidden due to the INTERSCTING LINE with a malus of 2600
Hi therem
Another (unfortunately quite extreme) example is mentioned here: the recent Genovese bridge collapse
I recommend to subscribe to that thread because we will announce further info over there.
Max Beermann
Post by Max Beermann »
Hey there,
is it also possible to block more than one bridge?
For example: I want to block "Mülheimer-Brücke" and "Leverkusener-Brücke"?
When I execute the following code > the routing only blocks the last one ("Leverkusener-Brücke").
      <ArrayOfExceptionPath_4>
        <ns6:ExceptionPath xmlns:ns6="http://xroute.xserver.ptvag.com" street="Mülheimer Brücke" relMalus="2501" extSegments="" binaryPathDesc="" absTimeMalus="0">
          <ns6:wrappedNodes xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
        </ns6:ExceptionPath>
        <ns6:ExceptionPath xmlns:ns6="http://xroute.xserver.ptvag.com" street="Leverkusener Brücke" relMalus="2501" extSegments="" binaryPathDesc="" absTimeMalus="0">
      </ArrayOfExceptionPath_4>
Thanks in advance
Max Beermann
Max Beermann
Development Manager
WHEELS Logistics
Hello Max,
honestly I wasn't aware of this little statement, too.
best regards,
https://xserver.ptvgroup.com/fileadmin/ ... eptionPath
Alternative description representing an optional list of segments which match certain street names resp. street numbers.
The list of segments includes all segments which match at least one of the street names resp. street numbers.
The syntax for this description is:
<streetname>[/<streetname>]*
absTimeMalus will be ignored if this attribute is non-empty, instead relMalus will be considered.
If more than one ExceptionPath elements contain a non-empty 'street' attribute, only the last occurrence will be considered.
calculateMatrixInfo() does not support this attribute.
Max Beermann
Hey Bernd,
thanks for your fast replay - works perfectly!
        <ns6:ExceptionPath xmlns:ns6="http://xroute.xserver.ptvag.com" street="[Mülheimer Brücke]/[Leverkusener Brücke]" relMalus="2501" extSegments="" binaryPathDesc="" absTimeMalus="0">
Happy new year!
Max
Max Beermann
Development Manager
WHEELS Logistics
PS: with xServer 2.26 we invented a new geographic restriction: prohibitedSegmentsByIntersectingPolylines
This enables users to block segments on a stable, coordinate based selection.
I applied this on the WarnowTunnel:
Looks good!
The benefit: with this approach you don't have to recreate your custom feature layers with every map update!
prohibitedSegmentsByIntersectingPolylines = [&quot;Linestring(12.092431 54.136726,12.094478 54.132741)&quot;]
prohibitedSegmentsByIntersectingPolylines = ["Linestring(12.092431 54.136726,12.094478 54.132741)"]
Re: Schiersteiner Brücke - how to deal with construction sites?
Short update about the LEVERKUSENER BRÜCKE
It has been reopened 4.2.2024 !
The screenshot below is based on the 2024.1H which is currenty behind XSI2. So in todays LIVE map the bridge is still blocked for
The next map version 2024.2H will reflect the "new situation" and is supposed to be available by the of february 2024 and then installed on XS.
Do not hesitate to get back to me if you have questions!
2024.1H : Truck attribute still set to &quot;maxWeight = 3500 kg&quot;
2024.1H : Truck attribute still set to "maxWeight = 3500 kg"
2024.1H : current &quot;traffic situation&quot; given by TOMTOM HD traffic (event started 4.2.2024 - expected to last 10 months - impact: speed reduced to 40km/h)
2024.1H : current "traffic situation" given by TOMTOM HD traffic (event started 4.2.2024 - expected to last 10 months - impact: speed reduced to 40km/h)
2024.1H
2024.1H
Here are some news about the Leverkusener Brücke:
It has been "reopened": https://www.ksta.de/region/leverkusen/a ... nrw-729702
2024.2H map: no critical attributes in the bridge
2024.1H map : the bridge is blocked via PTV TruckAttributes
