Hi all,
I got the following error when using Speedpatterns in calculateAdvancedTour:
"errorMessage": "calculate(Advanced)Tour does not support time dependency in feature layer configuration",
"errorKey": "2311",
"exceptionType": "com.ptvag.xserver.xroute.XRouteException"
Please can you exactly explain, what feature layer will work with calcAdvTour? I need calcAdvTour cause of time windows at the stations and start time optimization of the tour. I hoped it would work fine with time dependend feature layer? Most feature layer are time dependend.
Volker
Speedpatterns in calculate(Advanced)Tour
Lauterfeld
Volker Lauterfeld
COS GmbH
Raiffeisenstraße 21
D-77704 Oberkirch
http://www.cosonline.de/
COS GmbH
Raiffeisenstraße 21
D-77704 Oberkirch
Re: Speedpatterns in calculate(Advanced)Tour
Hello Volker,
not sure whether you can blame it on the feature layer itself. I made a quick test with the following snippet:
If the global timedependency is disabled it works, otherwise it fails.
The reason for this is probably the treatment of the attributes which do not depend on time. So such static attributes (e.g. some TruckAttributes) can be considered because they to not have an impact o the time dependent track.
But those who depend on time are critical, such as all SPEED PATTERNS.
<GlobalSettings enableTimeDependency="false"/>
<Themes>
<Theme id="PTV_SpeedPatterns" enabled="true"/>
</Themes>
</FeatureLayer>The reason for this is probably the treatment of the attributes which do not depend on time. So such static attributes (e.g. some TruckAttributes) can be considered because they to not have an impact o the time dependent track.
Lauterfeld
thanks for your comment!
I think disabling the global time dependency does not throw an error but it seems that xroute doesn't respect the speed patterns at all. My example tour through Vienna is always the same in distance and time, it doesn't matter if the START_TIME is at night or in the rush hour
. The documentation of xRoute confirms it, too. Unfortunately we did'nt know that. 95% of our xRoute implementation (also the routing polygon view on the leaflet map) refers to calcAdvTour. I got a heart attack seeing that
Volker
Volker
Volker Lauterfeld
COS GmbH
Raiffeisenstraße 21
D-77704 Oberkirch
COS GmbH
Raiffeisenstraße 21
D-77704 Oberkirch
Hello Volker,
There's a logical reason why the combination of
The tour approaches are based on a two step process:
Not that complicated to understand - but not obvious to see. Maybe we should improve our documentation.
At least this info explains why there's a conflict between the approaches.
Cheers,
- the tour approaches (incl. timeslots and service periods at stops)
- and dynamic routing = consideration of time dependent segment states (which is the core idea behind SpeedPatterns and required at least for some TruckAttibutes)
- calculate the way-time-scheme of a track (done by the router)
- insert the breaks/rests and service periods to match the additional constraints (done by the timecalc)
Cheers,
Hello Volker,
the attached image shows the difference in the approaches of xRoute 1 and 2 when it comes to time calculation.
XServer2 offers the possibility to compute daytime dependant matrices:
https://xserver2-europe-eu-test.cloud.p ... %7C_____13
IN one of the next versions of xServer 2 we will access such a matrix within the tour optimization...
