Toll Currency empty ("NONE")
skinder
Post by skinder »
we are facing problems with routings through Russia and Belarus using "calculateExtendedRoute". In the response document there are toll amounts which have no currency (value "NONE").
We are using xRoute v. 1.24.0.2. The CountryInfoOptions have "detailedTollCosts" and "currencyDescription" set to "true" in order to get detailed toll data.
In the response document the field "currencyISOCode" (of countryInfos) has a valid currency (i.e. "RUB" or "BYN"), but the child node "tollCostInfos" always has currency = "NONE".
According to the documentation of PTV xServer Version 1.24 the CountryInfoOptions.currency is deprecated and replaced by currencyISOCode, but I could not find a note that the currency field of the tollCostInfos would be also deprecated.
Is there a way to get the currency field in the tollCostInfos filled? Or is it reliable to just take the currencyISOCode of the parent countryInfos?
best regards,
Sascha Kinder
routing request example:
  "waypoints": [
      "coords": [
          "point": {
            "x": 43.4498,
            "y": 56.2389
      "linkType": "NEXT_SEGMENT"
      "coords": [
          "point": {
            "x": 21.228,
            "y": 55.66175
  "options": [],
  "exceptionPaths": [],
  "details": {
    "binaryPathDesc": false,
    "boundingRectanglesC": 5,
    "boundingRectanglesOffset": 300,
    "brunnelManoeuvres": false,
    "detailLevel": "STANDARD",
    "dynamicInfo": false,
    "manoeuvreAttributes": false,
    "manoeuvreGroupRatio": 1,
    "manoeuvreGroups": true,
    "manoeuvres": true,
    "nodes": false,
    "polygon": true,
    "segmentAttributes": false,
    "segments": true,
    "texts": true,
    "totalRectangle": false,
    "urbanManoeuvres": false
  "countryInfoOptions": {
    "allEuro": false,
    "detailedTollCosts": true,
    "currencyDescription": true,
    "reductionIDs": []
  "callerContext": {
    "properties": [
        "key": "ResponseGeometry",
        "value": "PLAIN"
        "key": "CoordFormat",
        "value": "OG_GEODECIMAL"
        "key": "Profile",
        "value": "truckfast"
Snippet from the xRoute response:
"countryInfos": [
      "iuCode": 18,
      "partRouteInfo": {
        "distance": 408348,
        "time": 26478,
        "cost": 364417
      "currency": "NONE",
      "currencyName": "Weißrussischer Rubel",
      "currencyISOCode": "BYN",
      "countryCode": "",
      "additionalInfo": "",
      "tollCostInfos": [
          "tollStationFrom": {
            "tollStationName": "",
            "tollStationID": -1,
            "tollLocationType": "NORMAL",
            "routeListIndex": -1
          "tollStationTo": {
          "tollSectionID": -1,
          "tollProviderID": 0,
          "tollDistance": 364417,
          "tollPrice": 6595,
          "tollType": "NATIONALTOLL",
          "currency": "NONE"
Re: Toll Currency empty ("NONE")
Hi Sascha,
looks buggy... I created a JIRA for this.
(MPXSRV-4253)
skinder
Post by skinder »
thanks for the information. For the time being we will use the currency of the CountryInfos then.
regards,
Sascha
Hello Sascha,
here is some info from DEV:
This is because there is no toll data available for IU 7016 (Russia Volga Federal District). You can check this with a view in the TollScenarios.ini. The corresponding IU (i.e. COUNTRYID 7016) is missing. And of course the same is true for the GP archive (rus-va_d.gp) with missing cid/cix files. But to return the currency we need this data. Another country without toll data is e.g. Finland. In case of routing there you also get no currency.
As far as I know there is a toll system in this country, but our data does not include it. Maybe we should concentrate on that and improve the toll data. Or is not the toll cost but only the currency relevant for the customer? That would make not much sense as the toll cost is always zero...
By the way: Russia is separated into several sub-areas. Might be the case that the values are available for some of those but not for all.
skinder
Post by skinder »
thank you again for the information.
So I understand there is no support for toll in (parts of) Russia and Finland.
But what about Belarus then? There are toll amounts in the response, but no currency. Is this country considered supported toll-wise?
Asterix wrote:
[...] Or is not the toll cost but only the currency relevant for the customer? That would make not much sense as the toll cost is always zero...
Our expectation is that whenever the routing response contains a toll amount > 0 a currency is provided as well.
( once again: forwarded to the JIRA )
