Consumer proxy by SAP
Fran
Post by Fran »
I'm trying to consume a web service with soapUI for:
1.- Calculate a Route
2.- Painting the route in the map (I have some problems here)
When it works correctly with soapUI i'm implementing consumer proxy in SAP.
To calculate Route using the operation calculateRoute from xRoute the XML requested is:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:typ="http://types.xroute.xserver.ptvag.com" xmlns:xro="http://xroute.xserver.ptvag.com" xmlns:com="http://common.xserver.ptvag.com" xmlns:wrap="http://wrappertypes.service.jabba.ptvag.com" xmlns:bas="http://baseservices.service.jabba.ptvag.com">
   <soapenv:Header/>
   <soapenv:Body>
      <typ:calculateRoute>
         <typ:ArrayOfWaypointDesc_1>
            <!--Zero or more repetitions:-->
            <xro:WaypointDesc fuzzyRadius="0" linkType="AUTO_LINKING">
               <xro:wrappedCoords>
                  <com:Point>
               <com:point x="2.205154" y="41.408409"/>
                  </com:Point>
               </xro:wrappedCoords>
            </xro:WaypointDesc>
               <xro:wrappedCoords>
                  <com:Point>
               <com:point x="2.213265" y="41.407335"/>
                  </com:Point>
               <xro:wrappedVehicleOptions>
                  <xro:VehicleOption parameter="TYPE" value="CAR"/>
               </xro:wrappedVehicleOptions>
            </xro:WaypointDesc>
         </typ:ArrayOfWaypointDesc_1>
         <typ:ResultListOptions_4 binaryPathDesc="true" polygon="true" totalRectangle="true" detailLevel="ALL">
            <!--Optional:-->
            <xro:cenEmissionConfiguration/>
            <!--Optional:-->
            <xro:destDetail/>
            <!--Optional:-->
            <xro:emissions/>
            <!--Optional:-->
            <xro:hbefaType/>
            <!--Optional:-->
            <xro:startDetail/>
         </typ:ResultListOptions_4>
         <typ:CallerContext_5>
            <bas:wrappedProperties>
               <bas:CallerContextProperty key="CoordFormat" value="OG_GEODECIMAL"/>
            </bas:wrappedProperties>
         </typ:CallerContext_5>
      </typ:calculateRoute>
   </soapenv:Body>
</soapenv:Envelope>
The response is:
   <soap:Body>
      <ns4:calculateRouteResponse xmlns:ns6="http://exception.core.jabba.ptvag.com" xmlns:ns2="http://baseservices.service.jabba.ptvag.com" xmlns:ns4="http://types.xroute.xserver.ptvag.com" xmlns:ns3="http://xroute.xserver.ptvag.com" xmlns:ns1="http://common.xserver.ptvag.com" xmlns:ns0="http://wrappertypes.service.jabba.ptvag.com">
         <ns4:result binaryPathDesc="qAAAACIAM1DIQLMAIgAzUMhAyAAiADNQyEDNACIANFDIQKQAIgA0UMhAmgAiADRQyEBLACIANFDIQFgAIgAzUMhAKgAiADNQyEAhACIAM1DJQH8AIgAzUMlAfQAiADNQyUBxACIAM1DJQG4AIgAzUMlAawAiADNQyUBoACIAM1DJQGEAIgAzUMlAWgAiADNQyUBMACIAM1DJQFAAIgAzUMlAVgAiADNQyUBqAA==">
            <ns3:wrappedBoundingRectangles xsi:nil="true" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
            <ns3:info cost="1699" time="143" distance="958"/>
            <ns3:wrappedManoeuvreGroup xsi:nil="true" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
            <ns3:wrappedManoeuvres xsi:nil="true" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
            <ns3:wrappedNodes xsi:nil="true" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
            <ns3:polygon>
               <ns1:lineString>
                  <ns1:wrappedPoints>
                     <ns1:PlainPoint y="41.408408096" x="2.2051317148"/>
                     <ns1:PlainPoint y="41.408992024" x="2.2059102735"/>
                     <ns1:PlainPoint y="41.409219105" x="2.2062562996"/>
                     <ns1:PlainPoint y="41.409770585" x="2.2069483517"/>
                     <ns1:PlainPoint y="41.409770585" x="2.206991605"/>
                     <ns1:PlainPoint y="41.410094983" x="2.2073808843"/>
                     <ns1:PlainPoint y="41.409770585" x="2.2078134169"/>
                     <ns1:PlainPoint y="41.409705705" x="2.2078566702"/>
                     <ns1:PlainPoint y="41.409640826" x="2.2079431767"/>
                     <ns1:PlainPoint y="41.409413746" x="2.2082459495"/>
                     <ns1:PlainPoint y="41.409251545" x="2.2085054691"/>
                     <ns1:PlainPoint y="41.408959583" x="2.2088947484"/>
                     <ns1:PlainPoint y="41.408732501" x="2.2091975212"/>
                     <ns1:PlainPoint y="41.408408096" x="2.2095868006"/>
                     <ns1:PlainPoint y="41.408181012" x="2.2098895734"/>
                     <ns1:PlainPoint y="41.407824164" x="2.2104086125"/>
                     <ns1:PlainPoint y="41.407532196" x="2.2107978918"/>
                     <ns1:PlainPoint y="41.406786049" x="2.2117927168"/>
                     <ns1:PlainPoint y="41.406656283" x="2.2119224766"/>
                     <ns1:PlainPoint y="41.406526517" x="2.2121387429"/>
                     <ns1:PlainPoint y="41.406494076" x="2.2121387429"/>
                  </ns1:wrappedPoints>
               </ns1:lineString>
            </ns3:polygon>
            <ns3:wrappedSegments xsi:nil="true" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
            <ns3:wrappedStations>
               <ns3:WayPoint countryCode="" wayPointType="START" manoeuvreIdx="0" segmentIdx="0" nodeIdx="0" polyIdx="0" iuCode="34" accDist="0" accTime="0">
                  <ns3:locationCoord>
                     <ns1:point y="41.408408096" x="2.2051317148"/>
                  </ns3:locationCoord>
                  <ns3:matchCoord>
                     <ns1:point y="41.408416905" x="2.2051434599"/>
                  </ns3:matchCoord>
               </ns3:WayPoint>
               <ns3:WayPoint countryCode="" wayPointType="DEST" manoeuvreIdx="17" segmentIdx="17" nodeIdx="20" polyIdx="20" iuCode="34" accDist="827" accTime="130">
                  <ns3:locationCoord>
                     <ns1:point y="41.407305108" x="2.2132633276"/>
                  <ns3:matchCoord>
                     <ns1:point y="41.406508395" x="2.2121629052"/>
                  </ns3:matchCoord>
               </ns3:WayPoint>
            </ns3:wrappedStations>
            <ns3:wrappedTexts xsi:nil="true" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
            <ns3:totalRectangle>
               <ns3:leftBottom>
                  <ns1:point y="41.406494076" x="2.2051317148"/>
               </ns3:leftBottom>
               <ns3:rightTop>
                  <ns1:point y="41.410094983" x="2.2121387429"/>
               </ns3:rightTop>
            </ns3:totalRectangle>
         </ns4:result>
      </ns4:calculateRouteResponse>
   </soap:Body>
</soap:Envelope>
For painting a map tried using xMap operation renderMapBoundingBox i pass the leftBottom and rightTop from calculateRoute to renderMapBoundingBox.
The requested is:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:typ="http://types.xmap.xserver.ptvag.com" xmlns:com="http://common.xserver.ptvag.com" xmlns:wrap="http://wrappertypes.service.jabba.ptvag.com" xmlns:xmap="http://xmap.xserver.ptvag.com" xmlns:bas="http://baseservices.service.jabba.ptvag.com">
   <soapenv:Header/>
   <soapenv:Body>
      <typ:renderMapBoundingBox>
         <typ:BoundingBox_1>
            <!--Optional:-->
            <com:leftTop>
               <com:point y="41.406494076" x="2.2051317148"/>
            </com:leftTop>
            <!--Optional:-->
            <com:rightBottom>
               <com:point y="41.410094983" x="2.2121387429"/>
            </com:rightBottom>
         </typ:BoundingBox_1>
         <typ:MapParams_2 language="ES" showScale="true" useMiles="false"/>
         <typ:ImageInfo_3 format="GIF" height="1400" width="2840" />
         <typ:boolean_5>false</typ:boolean_5>
         <typ:CallerContext_6>
         </typ:CallerContext_6>
      </typ:renderMapBoundingBox>
   </soapenv:Body>
</soapenv:Envelope>
And the response is:
   <soap:Body>
      <ns4:renderMapBoundingBoxResponse xmlns:ns6="http://exception.core.jabba.ptvag.com" xmlns:ns3="http://baseservices.service.jabba.ptvag.com" xmlns:ns4="http://types.xmap.xserver.ptvag.com" xmlns:ns2="http://xmap.xserver.ptvag.com" xmlns:ns1="http://common.xserver.ptvag.com" xmlns:ns0="http://wrappertypes.service.jabba.ptvag.com">
         <ns4:result>
            <ns2:image url="ims-eu-n-test.cloud.ptvgroup.com/IMS/CZWJQLIZJAHWLFAEM/0810-9848/1617247266-01804.gif?InstanceID=0"/>
            <ns2:wrappedObjects/>
            <ns2:visibleSection scale="7">
               <ns2:boundingBox>
                  <ns1:leftTop>
                     <ns1:point y="41.410094983" x="2.2037655303"/>
                  </ns1:leftTop>
                  <ns1:rightBottom>
                     <ns1:point y="41.406494076" x="2.2135049274"/>
                  </ns1:rightBottom>
               </ns2:boundingBox>
               <ns2:center>
                  <ns1:point y="41.408294554" x="2.2086352289"/>
               </ns2:center>
            </ns2:visibleSection>
         </ns4:result>
      </ns4:renderMapBoundingBoxResponse>
   </soap:Body>
</soap:Envelope>
The IMG is attached in post. But how i pass the route from Xroute to Xmap to painting it?
Thz for all.
Map
Map
MISTERX
Re: Consumer proxy by SAP
Post by MISTERX »
Dear Fran
please move your post/question to xMap-Forum, as your question is not SAP related.
Just a quick glance:
xMap doesn't know anything about (last) routing by xRoute.
You have to take the route (waypoints) from your xRoute response and to add this to your xMap request as addition.
Please refer to the xMap-API or examples of xMap-RawRequestRunner to see how to add objects to rendered map (e.g. POIs, routes etc.).
Kind Regards
Mr. X
  • Integration PTV <> SAP
  • Senior Consultant
Hello Fran, MisterX,
I've been told by sales that Fran probably uses the ABAT connectors.
So maybe we could answer his concrete SAP related demand considering the components in use.
From a generic perspective I agree with MisterX:
Probably it is a good idea to have a look at the level of access. Is it really about SAP technology stack? Then future posts are ok in this category.
If it is more a generic xServer topic dealing with raw parametrising of generic requests we should focus on the proper subforum.
Coming back to the current question. You have various options to visualize geometries on a map (polylines, polygones, points...):
  • using native xMap layers scuch as CustomLayer or GeometryLayer. The image returned by xMap then contains the additional geometry. Usually on top of the streets and towns. This approach is becoming less and less popular.
  • nowadays the xMap server is more a backend service that returns a map based on streets, towns and core objects such as forrests, rivers, mountains. The additional geometries are then painted on top via a layer technology that is maintained outside the xServer itself. So for example by using web based frameworks such as OpenLayers, Leaflet or the PTV ajaxmaps.
Get in touch with me 1:1 in case of further need of kickoff help.
MISTERX
Post by MISTERX »
Dear Fran,
dear Bernd
sorry my answer was perhaps a little bit crispy!
I didn't take into account that behind the scenes the abat-connector might be in use. It's always not easy to determine who's behind the user name :oops:
My sincere apologizes
Rolf
@Bernd: Thanks for your hints!
Mr. X
  • Senior Consultant
