Am I right, to enable a parallel tour calculation, just to set the xTour property of the poolsize from 1 to 2?
The number of module instances to be started as background processes.
poolSize=2
Thanks as alsways for your fast support!
Parallel Tour calculation
Re: Parallel Tour calculation
Hello Peter,
to give you a more generic response (based on xServer 1):
And you might need more memory and cores.
Regards Bernd
PS: further info is available here:
http://xserver.ptvgroup.com/fileadmin/f ... s%7C_____3
- Increasing the poolsize will ensure that a server starts several processes of same kind, e.g. xTourModule.exe
- each process can take care of a single transaction at the time
- you still have to ensure to avoid conflicts, e.g. by tho transactions trying to access the same distance matrix at the same time (refers to xCluster, xTour, xDima, xTerritory)
Regards Bernd
