Parallel Tour calculation
peter.detzner
Post by peter.detzner »
Am I right, to enable a parallel tour calculation, just to set the xTour property of the poolsize from 1 to 2?
The number of module instances to be started as background processes.
poolSize=2
Thanks as alsways for your fast support!
Re: Parallel Tour calculation
Hello Peter,
to give you a more generic response (based on xServer 1):
  • Increasing the poolsize will ensure that a server starts several processes of same kind, e.g. xTourModule.exe
  • each process can take care of a single transaction at the time
  • you still have to ensure to avoid conflicts, e.g. by tho transactions trying to access the same distance matrix at the same time (refers to xCluster, xTour, xDima, xTerritory)
So maybe the answer is just "yes" but be aware of conflicts, e.g. by defining individual DIMA IDs for the parallel transactions.
And you might need more memory and cores.
Regards Bernd
PS: further info is available here:
http://xserver.ptvgroup.com/fileadmin/f ... s%7C_____3
