Route Optimization OptiFlow API - Api Changes 1.42.0 (26.01.2026)
Questions refering to the Optiflow based API within PTV Developer (launched on 20.12.2023)
Route Optimization OptiFlow API1.42.0FEATURE26.01.2026Added a rule for adjusting task duration based on task and/or vehicle categories.
Route Optimization OptiFlow API1.42.0IMPROVEMENT26.01.2026Increased maximum number of categories to 100.
Re: Route Optimization OptiFlow API - Api Changes 1.42.0 (26.01.2026)
No endpoint changes (same /optimizations and related operations), but request/DTO capabilities expanded:
  • New “task rules” feature under rules.tasks (conditional duration modifiers for tasks).
  • Category lists got bigger: several categories arrays increased from maxItems: 50 → 100 (vehicles, tasks, depots, resources, orders, locations, compartments).
  • Minor doc-text tweak (whitespace in a description) — no behavioral impact.
1) New: rules.tasks (Task Rules)
What changed?
  • In v1.41, the Rules object only supported rules.locations.
  • In v1.42, Rules additionally supports rules.tasks as a list of task rules.
What is a Task Rule?
A TaskRule lets you conditionally modify task duration via a DurationModifier.
Each rule has:
  • conditions (OR-list; each condition is an AND-match)
  • duration (DurationModifier)
Conditions can match on:
  • taskCategory
  • vehicleCategory
Why it matters
This is a nice modeling upgrade if your service times depend on context, e.g.:
  • “Forklift-needed stops take +10 minutes”
  • “Big trucks are slower to handle at customer locations”
  • “Special handling categories increase service time”
Example (request snippet)
  "rules": {
    "tasks": [
        "conditions": [
          { "taskCategory": "FORK_LIFT_NEEDED" },
          { "vehicleCategory": "BIG_TRUCK" }
        "duration": { "factor": 1.0, "extra": 600 }
(Structure based on Rules.tasks + TaskRule + TaskRuleCondition + DurationModifier.)
:!: Compatibility note: This is an additive change. Existing clients should keep working; clients with strict validation/generation may need updated models to accept rules.tasks.
2) Bigger categories arrays (50 → 100)
Several schemas now allow up to 100 categories instead of 50.
Concrete example:
  • v1.41 ServiceOrderProperties.categories had maxItems: 50.
  • v1.42 Vehicle.categories has maxItems: 100.
  • v1.42 TaskProperties.categories has maxItems: 100.
  • v1.42 Resource.categories has maxItems: 100.
Impact
  • Usually non-breaking (it relaxes constraints).
  • But if you have client-side validators hard-coded to 50, you may want to bump those limits.
  • If you store categories in a DB column with limited size, this might increase payload sizes and storage needs.
3) Endpoints / Operations
I didn’t see any changes to the API surface (paths/operations look consistent between 1.41 and 1.42; the version bump is in the spec metadata).
Suggested action items (practical)
  • Update OpenAPI-generated client/server models to include rules.tasks, TaskRule, TaskRuleCondition.
  • If you validate categories length client-side, increase allowed max to 100 (where applicable).
  • Consider adding a small sample in your integration tests that includes rules.tasks (optional) to ensure forward compatibility.
