Determine the latest departure times of stations
kevinkrueger
Post by kevinkrueger »
Now, to output our departure times to our stations, we specified "ExactTimeConsiderationAtArrival" in the route calculation. Thereby we got the following error message:
"ExactTimeConsiderationAtArrival mode can not be used if TourRestrictions are requested.".
How can I solve this problem?
Re: Determine the latest departure times of stations
Hello Kevin,
in fact this error occurs because we do not compute the break- and rest rules while we create the route from the "reverse angle". Technically this would be possible but in such a case we would start to insert the breaks in the wrong way:
Imagine a driver who is completely refreshed but who needs a break after 4:30 hours.
Forward: based on a refreshed driver in ExactAtStart mode. This structure is what you'd like to get.
With "ExactAtArrival" we would insert the "first" break 4:30 back from the ArrivalTime and so on.
The output route of such an approach would probably display the "early" breaks way too early.
Now in this case I simulated the expected output with an (impossible) combination of "ExactAtArrival" and "Break- and Restrule of a refreshed driver". The first break occurs somewhere after 2:00 hours which is wrong.
What you could do to solve this: Apply an iterative approach
  • Perform a ExactAtStart-Routing with a reference time almost as the desired "arrival time".
  • Use the output arrival time to determine a "shift" period
  • Calculate the route again in "ExactAtStart"-Mode but translate the "start time"
Not the perfect solution but for most cases good enough.
PS: This video shows how we flood the network in a unidirectional case (such as ExactAtStart and ExactAtArrival).
quick update... though the following request does not mention "TourOptions" it fails with an
<soap:Text xml:lang="en">ExactTimeConsiderationAtArrival mode can not
 be used if TourRestrictions are requested.</soap:Text>
Request:
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://www.w3.org/2003/05/soap-envelope" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xs="http://xroute.xserver.ptvgroup.com" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <soap:Body>  <startCalculateRoute xmlns="http://xroute.xserver.ptvgroup.com">
    <request storedProfile="car" xmlns="">
      <requestProfile userLanguage="DE">
        <featureLayerProfile>
          <themes id="PTV_TruckAttributes" enabled="false" />
          <themes id="PTV_TrafficIncidents" enabled="false" />
          <themes id="PTV_TruckSpeedPatterns" enabled="false" />
        </featureLayerProfile>
        <routingProfile>
          <course distanceTimeWeighting="80" />
        </routingProfile>
      </requestProfile>
      <waypoints xmlns:q1="http://xroute.xserver.ptvgroup.com" xsi:type="q1:OffRoadWaypoint" name="1">
        <location>
          <offRoadCoordinate x="8.9" y="47.74" />
        </location>
        <tourStopOptions serviceTime="900" />
      </waypoints>
      <waypoints xmlns:q2="http://xroute.xserver.ptvgroup.com" xsi:type="q2:OffRoadWaypoint" name="2">
        <location>
          <offRoadCoordinate x="8.05" y="48.63" />
        </location>
      </waypoints>
      <routeOptions currency="EUR">
        <timeConsideration xmlns:q3="http://timeconsideration.xserver.ptvgroup.com" xsi:type="q3:ExactTimeConsiderationAtArrival" referenceTime="2022-12-22T00:00:00" />
      </routeOptions>
      <resultFields waypoints="true" nodes="true" polyline="true" tourReport="true" encodedPath="true" monetaryCostsReport="true">
        <legs enabled="true" polyline="true" tollSummary="true" emissions="true" />
        <segments enabled="true" emissions="true" polyline="true" descriptors="true" roadAttributes="true" id="true" />
        <eventTypes>TOUR_EVENT</eventTypes>
        <eventTypes>WAYPOINT_EVENT</eventTypes>
        <eventTypes>ROUTE_VIOLATION_EVENT</eventTypes>
        <eventTypes>TOLL_EVENT</eventTypes>
        <toll enabled="true" sections="true" systems="true" />
      </resultFields>
    </request>
  </startCalculateRoute>
</soap:Body>
</soap:Envelope>
Took me a few seconds to spot the various implicit causes:
  • The waypoints contain tourStopOptions.
  • The resultFields ask for tourReport="true"
  • The resultFields ask for <eventTypes>TOUR_EVENT</eventTypes>
Each one of these triggers the error in this case.
