Hey all together,
maybe someone could give me a good hint how to use a specific ROLA within a route calculation?
E.g. Wörgl-Brennero?
How to add a ROLA to the routing?
Uta Jäger-Frenk
Uta Jäger-Frenk
Support Specialist at PTV Logistics - Germany
Happy to help the products PTV Developer, PTV xServer, PTV Navigator G1 and G2
Re: How to add a ROLA to the routing?
The Data API offers the possibility to search for available combined transports, try this sample:
https://developer.myptv.com/en/document ... transports
Here's an excerpt when searching for "Rola":
If you find the connection you desire you can use them as a combined transport waypoint in the Routing API where you specify the start and destination coordinates of the combined transport.
The response even contains the string how it needs to be specified as query parameter in the Routing API:
"polyline": "{\"type\":\"LineString\",\"coordinates\":[[...]]}",
"name": "Rola Wörgl-Brenner", "duration": 18082, "type": "RAIL",
"start": {
"latitude": 47.482539082, "longitude": 12.033915862, "name": "Wörgl", "countryCode": "AT"
"destination": {
"latitude": 46.103613833, "longitude": 11.096358212, "name": "Trento", "countryCode": "IT"
"allowedFor": "VAN,TRUCK",
"waypointsParameter": "combinedTransport=47.482539082,12.033915862,46.103613833,11.096358212"
}The response even contains the string how it needs to be specified as query parameter in the Routing API:
combinedTransport=47.482539082,12.033915862,46.103613833,11.096358212Max
Developer
PTV Logistics
Developer
PTV Logistics
Hello Uta,
the ROLA (=Rollende Landstraße) is s so-called combined transport, in this case a piggyback:
- Therefore you may have to ensure that piggybacks are allowed (or even preferred) in the routing.
- A side effect of Combined Transports is their contribution to the travel distance: "0 meters" because you are not driving. To push towards Combined Transports you may therefore consider to use the routing to go for "shortest" instead of "fastest".
- If the comined transport you expect isn't chosen by the API automatically you may have to add a dedicated Waypoint type to your station list.
| API | PTV xServer2 / xRoute2 | PTV Developer Routing API |
| Consider piggyback | com.ptvgroup.xserver.routingprofile.CombinedTransport.railPenalty | RoutingAPI.Options.avoid (you can block but not prefer them) |
| Waypoint properties | com.ptvgroup.xserver.xroute.CombinedTransportViaWaypoint | Concept "CombinedTransports" |
| Where to get relevant properties? | com.ptvgroup.xserver.xdata.SegmentsRequest | DataAPI.getCombinedTransports() |
| Sample "Waypoints" | Code: Select all | Code: Select all |
| Attention | Segment IDs change from map version to map version. |
