How long is an optimization result stored?
How long can I retrieve a planning result through the getOptimizationResult method?
michael.unrau
Re: How long is an optimization result stored?
Post by michael.unrau »
Data retention policy is currently still under discussion.
Cheers,
Michael
Michael Unrau
DevOps Engineer
Awesome - meanwhile we added some convenience functions and I created a little admin frontend which enables me to
  • jump through the planning history
  • visualize various KPIs
:!: Very helpful - thanks!
FYI: In v 1.39 (19.01.2026) we added the parameter metadata.deletion which serves for a better housekeeping ;-)
deletion : string <date-time>
The deletion time of the optimization. Must be in the future and only applies to finished optimizations. Formatted according to RFC 3339, section 5.6.
  • Now in the past we removed all plannings 2 weeks after creationDate.
  • This is still the default behaviour if you do not specify the deletion date during the startOptimization.
  • We are now more flexible and trust you to perform some housekeeping by
    • Specifying a fair deletion date with the startOptimization
    • Or by removing you plannings every once in a while via deleteOptimization
    • Or by updating the deletion date via updateOptimizationMetadata
The column &quot;Metadata Deletion&quot; shows the deletion date.<br />In the VIRTUAL column &quot;Metadata TimeTillDeletion&quot; I calculated the remaining time on client side. As you can see in the 3rd row the date is in more than 3 weeks.
The column "Metadata Deletion" shows the deletion date.
In the VIRTUAL column "Metadata TimeTillDeletion" I calculated the remaining time on client side. As you can see in the 3rd row the date is in more than 3 weeks.
