Map&Guide Internet road blocks in xServer1
Quick question about MGI & xServer1 comparsion.
One of our client is missing the possibilities in our solution for considering road blocks when routing.
In MGI there are 3 settings for this one, shown in the attached picture:
- Include all traffic disruptions
- Include all blocks
- Only include permanent roadblocks...
Could you describe the difference between these 3 settings, and also tell us which parameters have to be setted in the routing profile to get the same results as in MGI?
It must be somehow with the PTV_SpeedPatterns, and PTV_TrafficIncidents layers, but we're a bit confused, how to pair them with the MGI settings.
Thank you in advance!
Peter
Peter
Re: Map&Guide Internet road blocks in xServer1
Hello Peter,
that's a huge challenge - and we need to talk about some very old xServer1 technology called traffic info loader / geodata source.
The following code is based on a so-called GEODATASOURCE LAYER (Routing Option) with a base value of "traffic.ptv-traffic.default".
This works OUTSIDE the snippets. YOu may also look for TRAFFIC INFO LOADER to get further details about this.
By applying this layer / routing option you tell the service to consider an alternative data source that contains the traffic incidents data. (This is NOT the same as FL PTV_TrafficIncidents !)
Each "traffic event" has properties such as
Below is the code that shows the manipulation.
Does this help?
But honestly I recommend to set up a session with me...
- validity period
- category (full blocking, lane reduction, ...)
- coordinates from / to
Does this help?
#region TrafficInformation
options.ConsiderTrafficInformation = false;
if (!vehicleData.SystemProfile)
options.TrafficInformationLayerName = TRAFFIC_INFO_LAYER_NAME + ";" + "c_category > 0";
//consider traffic information
switch (sunriseRequest.ViRequest)
case SRTrafficInfoRoutingRequest.NoConsideration:
break;
case SRTrafficInfoRoutingRequest.ConsiderAll:
options.ConsiderTrafficInformation = true;
break;
case SRTrafficInfoRoutingRequest.Blocks:
options.TrafficInformationLayerName += " AND c_category BETWEEN 50 AND 59";
break;
case SRTrafficInfoRoutingRequest.LongTimeRoadWorks:
options.TrafficInformationLayerName += " AND (c_category BETWEEN 50 AND 59 OR c_category BETWEEN 110 AND 119) AND computed_duration > 1";
break;
//Igrore Truck-Blockings (Category=53) for CARs and VANs
if (vehicleData.TransportClass != TransportClassification.TRL && vehicleData.TransportClass != TransportClassification.TRU)
options.TrafficInformationLayerName += " AND c_category <> 53";
//Not meaningful if most of the blockings are valid for less than 15mins
//options.TrafficInformationLayerName += " AND " + GetTILValidityQuery(options.Time.AddMinutes(options.UTCOffset));
#endregion
Sorry, I've missed this feedback.
As we plan to switch to Developer in the future: is it easier to implement this one in Developer?
Thank you,
Peter
Thank you,
Peter
Hello Peter.
About the comparison with PTV Developer:
I need to talk to DEV/PM first. I'll trigger them and ask for a statement...
PS:
to avoid missing info you can subscribe to a topic (or a whole category).
PS:
I've discussed with our dealer partner, and this one is quite urgent.
Is there any other way to somehow include the permanent road block in xServer1 routing?
The PTV Developer answer is also important, as that could be a solution later this year.
Thank you,
Peter
Thank you,
Peter
I've came with an example. Maybe this could bring us closer to the solution.
DE 09 Chemnitz
DE 09569 Oederan.
1. Map&Guide Internet:
As you can see, there is an ongoing road work, between Flöha and Falkenau.
MGI knows this one, so it skips that segment and gives a longer, but possible route. 2. xServer1:
On the raffice map layer, we also visualize this roadblock, however in xServer1 this roadblock is bypassed. I also attached the xServer1 request.
Thank you,
Peter
DE 09 Chemnitz
DE 09569 Oederan.
Thank you,
Peter
- Attachments
- xserver1.log
- (9.46 KiB) Downloaded 989 times
HI Peter,
here's some footage... processed through xroute-eu-h-test / Raw Request Runner:
Here's a routing request with the option set to consider that layer
Is this what you've been looking for?
"options": [
"parameter": "GEODATASOURCE_LAYER",
"value": "traffic.ptv-traffic.default"
"waypoints": [
"$type": "WaypointDesc",
"linkType": "NEXT_SEGMENT",
"fuzzyRadius": 0,
"coords": [
"$type": "Point",
"point": {
"$type": "PlainPoint",
"x": 12.92087,
"y": 50.8367
"fuzzyRadius": 0,
"coords": [
"$type": "Point",
"point": {
"x": 13.16793,
"y": 50.86223
"exceptionPaths": null,
"details": {
"manoeuvres": true,
"polygon": true,
"detailLevel": "STANDARD",
"segments": true,
"featureDescriptions": true
"callerContext": {
"properties": [
"key": "CoordFormat",
"value": "OG_GEODECIMAL"
"key": "ResponseGeometry",
"value": "WKB"
"key": "Profile",
"value": "carfast"
Hi Dear Bernd,
We've started testing the solution you've suggested, and it passed the first tests!
We've decided to integrate this feature, as disabled by default.
I don't want to take more of your precious time right now. If we experience some malfunctions in the live tests, I'll get back to you!
If you have any information on the Developer version, please post in the forum!
Thank you again for your help!
Peter
Peter
Hi Peter,
just some screenshots from DEVELOPER: Bernd
That looks great! It's the same problem, and so it also work in Developer.
https://developer.myptv.com/en/document ... ulateRoute
As I can see, It's much easier in Developer then, only need to switch the trafficMode option to Realistic from Average.
Another plus point for switching to Developer.
Thank you,
Peter
Thank you,
Peter
Hi Peter,
In fact the concept of Developer is to offer "stories which are easy to understand" instead of "technical features which are mighty but at the same time too complex"
From my perspective the native xserver2 is an extremely flexible and powerful interface but sometimes just too hard to be handeled properly without consulting advice...
The downsize of Developer is that not every native feature is accessible through it's implified "glasses" (so far) but nevertheless users can pick the API version that is sufficient in terms of flexibility and simple in terms of complexity...
