Calculated toll distance greater than total distance
Pete
Post by Pete »
When calculating a route just inside of Germany (to keep things simple) we need to know the total toll distance for the route.
We do this by look at the "toll.sections" collection and add up the "officialDistance" property for all sections.
Over time we noticed that the sum of the toll.sections can be greater the "distance" property of the response which should be the total distance of the route.
Looking at the toll sections in detail, we noticed sometimes sections appear twice, which obviously screws up the result. But even after filtering out duplicates we still have cases where the sum of the officialDistances are greater than the total distance of the route.
Are we doing something wrong here, is there a different (better) way to get the total toll distance?
Or is this a known problem?
Peter Hahndorf
Senior Software Engineer
indiwa digitale kommunikation GmbH
Max
Re: Calculated toll distance greater than total distance
Post by Max »
The officialDistance is not available for every toll system as not every toll operator provides this information. In Germany, this information is provided by the government and they even describe how they determine their section lengths: https://www.balm.bund.de/DE/Themen/Lkw- ... _node.html
I can think of a few reasons why the official distances and the total distance of the route may differ, for example the measured distance while driving versus the calculated distance from polyline coordinates (even within the latter there can be differences due to different methods and projections).
I would be very interested in requests where a section appears twice. Those would be bugs in our toll data and of course we want to fix them. There is an explanation why a section can appear twice, that is when there is a waypoint in between where you leave the toll road.
If a section is only partially driven (very hard to find an example where this actually could happen), then it also makes sense that the reported distance is less than the toll distance.
But I guess you are referring to routes that span several hundreds of kilometers through Germany. I assume that there are some systematic errors where our distance might be slightly lower than the actual distance whereas the official distance might be a bit greater than it actually is. I don't think you're doing something wrong and yes, there is a different way to get the total toll distance. You can request the toll events. At each event there is a distanceFromStart returned. So you calculate the difference exitTollEvent.distanceFromStart - enterTollEvent.distanceFromStart and add this up for each pair of enter and exit toll events.
This should work quite well with most toll systems. However, there are also toll events of type "PASS". There it is very difficult to get a good approximation of the toll distance if no official distance is available. At waypoints there is not necessarily an exit toll event, so if you want the toll distance per leg with this approach, you probably want the waypoint events too, so that you can split the distance accordingly.
There are plans to extend the xRoute 2 API to include the toll distance, however I don't know if it will make it to the next release 2.29 or later. So this is a good opportunity to make some wishes for the API. ;)
Max
Developer
PTV Logistics
Pete
Post by Pete »
Here is an example of a case where we had duplicate toll secions:
DE-21129 Hamburg, Am Ballinkai 1 - N 53.5085 E 9.9284
to
DE-91275 Auerbach - N 49.6949 E 11.6191
we had 114 toll sections, with two duplicates:
Trockau - Bayreuth-Süd 16000m
Rudolphstein - Bad Lobenstein 4600m
I hope this is helpful
Peter Hahndorf
here's a quick update from our data squad ;-)
The problem (175070) is known and understood and will be handled with an upcoming German toll update...
So stay tuned!
Here's another example of a routing result where the sum of the toll sections "officialDistance" exceeds the total distance (this time gathered through PTV Developer Routing API):
575,188 km = 100.0 % = Total Distance<br />567,490 km = 98,66 % = CalculatedDistance<br />577,800 km = 100,45 % = OfficialDistance
I'd say that the data coming from the TOLL provider simply differs from the MAP provider data which we use for the calculatedDIstance and the totalDistance.
@Max: Does this make sense?
Good to know: The Technical Concept "Toll" within the PTV Developer Routing API.
And two more samples:
  • To compute the calculatedDistance / officialDistance per country as shown in this screenshot it is necessary to evaluate the toll sections which provide the details which you can aggregate on client side:
  • :!: Please be aware that the official distance ist not available in all countries - that's why we have the calculated distance. Here's an example for the french route from Paris to Lyon:
      "waypoints": [
        "48.8571701049805,2.3413999080658;name=FRA/Île-de-France/Paris Paris",
        "45.7591705322266,4.82964992523193;name=FRA/Auvergne-Rhône-Alpes/Rhône Lyon"
      "profile": "EUR_TRUCK_40T",
      "vehicle": {
        "lowEmissionZoneApprovals": "",
        "hazardousMaterials": "",
        "truckRoutes": "",
        "etcSubscriptions": ""
      "options": {
        "routingMode": "FAST",    "language": "EN",    "currency": "EUR",    "avoid": "",    "speedFactor": 1.0
      "monetaryCostOptions": {},
      "results": [
        "POLYLINE", "TOLL_COSTS", "TOLL_EVENTS", "TOLL_SECTIONS", "TOLL_SYSTEMS"
    The response contribution for France does not contain "officialDistance"... only the calculatedDIstance.
    "sections": [
            "tollRoadType": "GENERAL",
            "costs": [
                "price": 114.83,
                "currency": "EUR",
                "paymentMethods": [
                  "ELECTRONIC_TOLL_COLLECTION",
                  "CASH",
                  "CREDIT_CARD"
                "convertedPrice": {
                  "price": 114.83,
                  "currency": "EUR"
            "countryCode": "FR",
            "displayName": "FLEURY-EN-BIERE - VILLEFRANCHE-LIMAS",
            "calculatedDistance": 407047
