Ferry Bilbao - Rosslare
RicardoSerrano
Post by RicardoSerrano »
There is one ferry route that is not included in PTV xServer Internet.
It is the ferry Bilbao(ES) - Rosslare(IR).
Do you know when it will be available?
I don't know how this kind of update works.
https://www.brittany-ferries.co.uk/map/ ... flex=0&p=1
https://www.brittany-ferries.es/rutas/f ... re/resumen
Thank you for your support.
Re: Ferry Bilbao - Rosslare
Ola Ricardo,
I assume you refer to the current TOMTOM map (https://xroute-eu-n.cloud.ptvgroup.com/xroute/ws/XRoute). At least the HERE map shows a connection between Bilbao/Algorta and Rosslare. (CHeck Screenshot below)
OK, here's how to proceed with such (no-)findings :
  • please open a regular support ticket and let my colleagues know that you are desperately looking for the mentioned connection (I can't do this for you, sorry).
PS: If you are dealing with the 2022.2 HERE map it might be helpful to change the boat penalty.
SCreenshot taken froim the 2022.2H / HERE map. There's ferry connection which is used if the ferry malus aka boatPenalty is set to a "magnetic" value (in my sample -20 was sufficient).
RicardoSerrano
Yes, we use Tomtom maps.
I have also used boatPenalty for forcing.
On the other hand, I searched with GetSegments (by SegmentsByCoordinateRequest, -3.0684206, 43.3509482 port of Bilbao) and the only result was:
"Bilbao-Portsmouth".
Thanks, I will open a support ticket.
