How to connect PTV xServer.NET with PTV Developer?
HI there,
recently I've been asked by partners about how to access PTV Developer raster maps through the well known PTV xServer.NET control.
Some of you are probably used to set the following properties in a formsMap:
Initially implemented "features" for access to xServer1 and xServer2. They haven't been migrated to PTV Developer Maps.
:!: This does not work with PTV Developer - you have to switch to the generic approach for REST based tiled layers (which by the way also enables you to use and other tiled based service such as weather maps or satellite images from other sources).
Sensei Oliver created a sample project for you: https://github.com/oliverheilig/PtvDeveloperForms
Most obvious difference between "xMap" and "Developer" is the usage via a RemoteTiledProvider:
new TiledLayer("Raster")
    TiledProvider = new RemoteTiledProvider
        MinZoom = 0,
        MaxZoom = 22,
        RequestBuilderDelegate = (x, y, z) =>
        $"https://api.myptv.com/rastermaps/v1/image-tiles/{z}/{x}/{y}?style=silica&apiKey={apiKey}",
    IsBaseMapLayer = true,
    Copyright = "© 2022 PTV Group, HERE",
    Caption = MapLocalizer.GetString(MapStringId.Background),
    Icon = ResourceHelper.LoadBitmapFromResource("Ptv.XServer.Controls.Map;component/Resources/Background.png")
(Source taken from Form1.cs)
Sample Projtct - I am using the windows system to provide the API key. The sample project then computes a route polyline and visualizes it together with symbols for start and destination waypoint.
