Best practices : gather toll as quick as possible
Cheers,
from time to time I get asked how to gather the toll prices for a relation A:B as quick as possible. Users try to apply which seem to be promising to them but from my perspective I recommend to take care of the following constraints:
  • Some countries apply toll based on the time of the day. To gather such contributions properly you need to apply a proper time dependency aka TimeConsiderationMode, e.g. SNAPSHOT or ExactTimeConsiderationAtStart or ExactTimeConsiderationAtArrival. :!: If you apply no such mode or Optimistic you may loose contributions.
  • If a time consideration mode is applied you can probably not benefit from HighPerformanceRouting but have to use RoutingType=CONVENTIONAL. ( :!: Though HPR supports Optimistic and Snapshot there are no such graphs available in the XSI cloud).
  • Do not forget to activate the proper feature layers such as PTV_TruckAttributes and PTV_TruckSpeedPatterns (or PTV_SpeedPatterns). Keep in mind that each additional feature layer has a negative impact on the performance. In my opinion the SpeedPatterns might not be helpful on long distance relations.
  • :idea: If you do not use HPR you might activate the GeographicRestriction with automatic search space bounds.
There's no such thing as a simple template request - it is always useful to rethink your specific story / approach depending on whether you need the price at "tender time" (exact start time not known) or "right before driving" (start time might be known).
Sample route from DE-Mannheim to IT-Napoli (no feature layers activated)<br />Three times the same driving time and distance, but different toll prices. This is because of the different TimeConsiderationModes I applied.<br /><br />As NONE, OPTIMISTIC and TIMESPAN do not consider the daytime dependent toll in Austria the prices are lower than with ExactAtStart/ExactAtArrival and Snapshot.
