Toll costs details (c#) (xsers-1330)
Hi
Any example of how to get toll costs details?
- Oliver Heilig
Re: Toll costs details (c#)
Hello vnsilva,
do you need C# sample code for a specific xServer API function, or a general sample that shows which api to use for getting detailed toll?
Oli
Oli
Oliver Heilig
PTV GROUP - Germany
PTV GROUP - Germany
Hi
If can provide a general sample that shows which api to use for getting detailed toll...
Thank you.
Thank you.
The quickest way to test toll calculation is to register for an xServer internet test account (if you have not done already) at https://www.ptvgroup.com/en/solutions/p ... /test-now/ . General information on how to connect to the cluster can be found at http://xserver.ptvgroup.com/en-uk/cookb ... g-started/ . An overview of the different clusters can be found at http://xserver.ptvgroup.com/dk/cookbook ... formation/ .
Them comes the choose between API version 1 and API version 2. At time of writing API version 1 only supports toll calculation in Europe. API version 2 supports toll calculation in USA with support for Europe scheduled this fall. My best guess would be that atm you need toll calculations for Europe so I would advise to use API version 1 for now.
A collection of small samples with explain use case step be step can be found at:
http://xserver.ptvgroup.com/fileadmin/f ... mples.html
Reference documentation for version 1 can be found at:
https://xserver.ptvgroup.com/fileadmin/ ... ation.html
Hi
After some progress, I need help... again
I have a case that does not return values, I do not know if I'm doing something wrong.
this example there is a passage through a toll, but the PTV return 0€.
Point A Coords: -8,4276403; 41,5454854
Point B Coords: -8,2917857; 41,44253
var rOption = new RoutingOption[] {
new RoutingOption{parameter=RoutingParameter.ROUTE_LANGUAGE, value="PT"},
new RoutingOption{parameter=RoutingParameter.OPTIMIZATION, value="100"},
new RoutingOption{parameter=RoutingParameter.ALLOW_SEGMENT_VIOLATIONS, value="True"},
new RoutingOption{parameter=RoutingParameter.AVOID_HIGHWAYS, value="0"},
var callerContext = new CallerContext {
wrappedProperties = new[] {
new CallerContextProperty { key = "CoordFormat", value = "PTV_SMARTUNITS" },
new CallerContextProperty { key = "ResponseGeometry", value = "WKB" },
new CallerContextProperty { key = "Profile", value = "Truckfast"}
xRoute.BegincalculateExtendedRoute(data.RequestWaypoints, rOption, null, new ResultListOptions { polygon = true },
new CountryInfoOptions {
detailedTollCosts = true,
calculatePartTollCosts = true,
namedToll = true,
tollTotals = true,
allEuro = true,
}, callerContext, RouteExtentedCalculated, data);
private void RouteExtentedCalculated() {
var routeExtended = xRoute.EndcalculateExtendedRoute(result);
// create snapshot out of route result
routeSnapshot = RouteSnapshot.FromXRoute(
routeExtended.route.wrappedStations.Select(w => w.polyIdx).ToArray(),
wkbReader.Read(routeExtended.route.polygon.wkb).Coordinates.Select(p => p.PtvSmartUnitsToWgs84()).ToArray(),
routeExtended.route.info,
routeExtended.wrappedCountryInfos
Hi Valter,
looks buggy, indeed. I created a Jira (XSERS-1330).
We get back with a statement from DEV soon.
- Attachments
- XSERS-1330.response.xml
- response
- (200.14 KiB) Downloaded 516 times
- XSERS-1330.request.xml
- request
- (4.05 KiB) Downloaded 499 times
Re: Toll costs details (c#) (xsers-1330)
in the meantime we made some analysis:
- Our data experts were able to reproduce
- The provider data does not mention toll on the given section
- Technically spoken: the server does a proper job
I'm having trouble again, I can not get the value of truck tolls.
The value returned is for a CAR
Can help?
I'm passing the following parameters...
Can help?
rtOptimization = new RoutingOption { parameter = RoutingParameter.OPTIMIZATION, value = "100" },
new RoutingOption { parameter = RoutingParameter.AVOID_HIGHWAYS, value = "0" }
CountryInfoVehicleOptions countryInfoVehicleOptions = new CountryInfoVehicleOptions();
countryInfoVehicleOptions.namedToll = true;
countryInfoVehicleOptions.allEuro = true;
countryInfoVehicleOptions.detailedTollCosts = true;
countryInfoVehicleOptions.calculatePartTollCosts = true;
countryInfoVehicleOptions.tollTotals = true;
countryInfoVehicleOptions.wrappedOptions = new VehicleOption[]{
new VehicleOption {parameter = VehicleParameter.TYPE, value = "TRU" },
new VehicleOption {parameter = VehicleParameter.TOTAL_WEIGHT, value= "15000"},
new VehicleOption {parameter = VehicleParameter.TRAILER_WEIGHT, value= "20000"},
new VehicleOption {parameter = VehicleParameter.NUMBER_OF_AXLES, value= "4"},
new VehicleOption {parameter = VehicleParameter.HEIGHT, value= "400"},
new VehicleOption {parameter = VehicleParameter.LENGTH, value= "2000"},
new VehicleOption {parameter = VehicleParameter.EMISSION_CLASS, value= "EURO_4"},
countryInfoVehicleOptions, callerContext, RouteExtentedCalculated, data);
please capture the complete request and response (xml or JSON) which is exchanged with the interface.
I need to see all details.
If needed we could set up a websession 1:1 but this will require a proper schedule.
capture done...
Resquest
Response
Resquest
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/">
<s:Body xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<calculateExtendedRoute xmlns="http://types.xroute.xserver.ptvag.com">
<ArrayOfWaypointDesc_1>
<WaypointDesc xmlns="http://xroute.xserver.ptvag.com" fuzzyRadius="0" linkType="AUTO_LINKING">
<wrappedCoords>
<kml xsi:nil="true" />
<point x="3946845" y="5135369.0000000009" />
</Point>
</wrappedCoords>
<nodeID xsi:nil="true" />
<viaType xsi:nil="true" />
</WaypointDesc>
<wrappedCoords>
<point x="3961254.0000000005" y="5209817" />
</Point>
</wrappedCoords>
</WaypointDesc>
</ArrayOfWaypointDesc_1>
<ArrayOfRoutingOption_2>
<RoutingOption xmlns="http://xroute.xserver.ptvag.com" parameter="ROUTE_LANGUAGE" value="PT" />
<RoutingOption xmlns="http://xroute.xserver.ptvag.com" parameter="OPTIMIZATION" value="80" />
<RoutingOption xmlns="http://xroute.xserver.ptvag.com" parameter="ALLOW_SEGMENT_VIOLATIONS" value="True" />
<RoutingOption xmlns="http://xroute.xserver.ptvag.com" xsi:nil="true" />
</ArrayOfRoutingOption_2>
<ArrayOfExceptionPath_3 xsi:nil="true" />
<ResultListOptions_4 totalRectangle="false" tollManoeuvres="false" texts="false" segments="false" segmentAttributes="false" polygon="true" nodes="false" manoeuvreGroups="false" urbanManoeuvres="false" manoeuvreAttributes="false" dynamicInfo="false" detailLevel="BORDERS" brunnelManoeuvres="false" boundingRectanglesOffset="0" boundingRectanglesC="0" binaryPathDesc="false" manoeuvres="false">
<cenEmissionConfiguration xmlns="http://xroute.xserver.ptvag.com" xsi:nil="true" />
<destDetail xmlns="http://xroute.xserver.ptvag.com" xsi:nil="true" />
<emissions xmlns="http://xroute.xserver.ptvag.com" xsi:nil="true" />
<hbefaType xmlns="http://xroute.xserver.ptvag.com" xsi:nil="true" />
<startDetail xmlns="http://xroute.xserver.ptvag.com" xsi:nil="true" />
</ResultListOptions_4>
<CountryInfoOptions_5 xmlns:q1="http://xroute.xserver.ptvag.com" xsi:type="q1:CountryInfoVehicleOptions" allEuro="true" calculatePartTollCosts="true" detailedTollCosts="true">
<q1:wrappedReductionIDs xsi:nil="true" />
<q1:wrappedTollScenarios xsi:nil="true" />
<q1:wrappedOptions>
<q1:VehicleOption parameter="TYPE" value="TRL" />
<q1:VehicleOption parameter="TOTAL_WEIGHT" value="15000" />
<q1:VehicleOption parameter="TRAILER_WEIGHT" value="20000" />
<q1:VehicleOption parameter="NUMBER_OF_AXLES" value="4" />
<q1:VehicleOption parameter="HEIGHT" value="400" />
<q1:VehicleOption parameter="LENGTH" value="2000" />
<q1:VehicleOption parameter="EMISSION_CLASS" value="EURO_4" />
</q1:wrappedOptions>
</CountryInfoOptions_5>
<CallerContext_6>
<CallerContextProperty key="CoordFormat" value="PTV_SMARTUNITS" />
<CallerContextProperty key="ResponseGeometry" value="WKB" />
</wrappedProperties>
</CallerContext_6>
</calculateExtendedRoute>
</s:Body>
</s:Envelope>
<soap:Body>
<ns4:calculateExtendedRouteResponse xmlns:ns4="http://types.xroute.xserver.ptvag.com" xmlns:ns0="http://wrappertypes.service.jabba.ptvag.com" xmlns:ns1="http://common.xserver.ptvag.com" xmlns:ns2="http://baseservices.service.jabba.ptvag.com" xmlns:ns3="http://xroute.xserver.ptvag.com" xmlns:ns6="http://exception.core.jabba.ptvag.com">
<ns4:result>
<ns3:wrappedCountryInfos>
<ns3:CountryInfo additionalInfo="" countryCode="" currency="EUR" iuCode="51">
<ns3:partRouteInfo cost="0" time="28700" distance="378537" />
<ns3:wrappedPerNCRouteInfo>
<ns3:RouteInfo cost="0" time="0" distance="0" />
<ns3:RouteInfo cost="0" time="33" distance="1081" />
<ns3:RouteInfo cost="0" time="17941" distance="263286" />
<ns3:RouteInfo cost="0" time="7549" distance="87211" />
<ns3:RouteInfo cost="0" time="3120" distance="26703" />
<ns3:RouteInfo cost="0" time="57" distance="256" />
</ns3:wrappedPerNCRouteInfo>
<ns3:wrappedPerTypeTollDistance>
<ns0:Int>0</ns0:Int>
</ns3:wrappedPerTypeTollDistance>
<ns3:wrappedPerTypeTollPrice>
<ns0:Int>16</ns0:Int>
</ns3:wrappedPerTypeTollPrice>
<ns3:wrappedTollCostInfos>
<ns3:TollCostInfo currency="EUR" tollType="NATIONALTOLL" tollPrice="16" tollDistance="0" tollProviderID="23" tollSectionID="57665">
<ns3:tollStationFrom manoeuvreType="ENTER" routeListIndex="4215" tollLocationType="AE" tollStationID="3024" tollStationName="A4portico1 (entre Custoias-Via Norte Nascente)" />
<ns3:tollStationTo manoeuvreType="EXIT" routeListIndex="4215" tollLocationType="AE" tollStationID="3024" tollStationName="A4portico1 (entre Custoias-Via Norte Nascente)" />
</ns3:TollCostInfo>
</ns3:wrappedTollCostInfos>
</ns3:CountryInfo>
</ns3:wrappedCountryInfos>
<ns3:wrappedPartTollCosts>
<ns3:PartTollCosts distance="0">
<ns3:wrappedCosts>
<ns3:TollCost type="NATIONALTOLL" iuCode="51" currency="EUR" cost="16" />
</ns3:wrappedCosts>
</ns3:PartTollCosts>
</ns3:wrappedPartTollCosts>
<ns3:route>
<ns3:wrappedBoundingRectangles xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
<ns3:info hasViolations="false" cost="340620" time="28700" distance="378541" />
<ns3:wrappedManoeuvreGroup xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
<ns3:wrappedManoeuvres xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
<ns3:wrappedNodes xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
<ns3:polygon wkb="....Removed..." />
<ns3:wrappedSegments xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
<ns3:wrappedStations>
<ns3:WayPoint countryCode="" wayPointType="START" manoeuvreIdx="-1" segmentIdx="0" nodeIdx="0" polyIdx="0" iuCode="51" accDist="0" accTime="0">
<ns3:locationCoord wkb="AAAAAAFBThyugAAAAEFTlwJAAAAA" />
<ns3:matchCoord wkb="AAAAAAFBThyusNnzy0FTlwImDDZ9" />
</ns3:WayPoint>
<ns3:WayPoint countryCode="" wayPointType="DEST" manoeuvreIdx="0" segmentIdx="4312" nodeIdx="4815" polyIdx="5417" iuCode="51" accDist="378537" accTime="28700">
<ns3:locationCoord wkb="AAAAAAFBTjjTAAAAAEFT37ZAAAAA" />
<ns3:matchCoord wkb="AAAAAAFBTjjTSzcRdkFT37ZRde0y" />
</ns3:WayPoint>
</ns3:wrappedStations>
<ns3:wrappedTexts xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
</ns3:route>
</ns4:result>
</ns4:calculateExtendedRouteResponse>
</soap:Body>
</soap:Envelope>
