Possible depot scenarios
Hello together,
recently I've been asked whether our tour planning software is able to cover the following scenarios regarding the assignment of depots (parametrization of depotIdStart and depotIdEnd is mentioned below).
Here are the different usage scenarios:
  • Round trips - start and end of a tour is at the same depot (startDepotID==endDepotID, startDepotID>0). Driver gets back to the depot at the end of a tour.
    roundtrip tour
    roundtrip tour
  • Open end trips - either tour starts at depot but ends at customer (startDepotID>0 and endDepotID==-1). Usually meaningful if the driver doesn't get paid for the final section from last customer back to the depot.
    open end
    open end
  • Open start trips - either tour starts at a customer but ends at the depot (startDepotID==-1 and endDepotID>0). Usually meaningful if the driver doesn't get paid for the initial section from depot to first customer.
    open end
    open end
  • Open trips - mixture of the scenarios above: start and end of a tour is somewhere at a customer (startDepotID==-1 and endDepotID==-1). Usually required if the driver doesn't get paid for the section from depot to first customer and his way from the last customer to the depot.
    open tour
    open tour
  • Inter depot trips - tour starts at depot and ends at depot but the depots are different (startDepotID>0 and endDepotID>0 and startDepotID!=endDepotID)
    inter depottrip
    inter depottrip
While the round trip enables the driver to fullfill several tours during a plan all the other scenarios will return single tours (compare it with balancing: doesn't make sense otherwise :lol: )
I also attached some images that demonstrate the given tour structures.
In xTour1 the relevant properties are
com.ptvag.xserver.xtour.AbstractVehicle:
  • AbstractVehicle.depotIdStart int The unique key to identify the related start depot clearly (> 0). The start depot is the site where the vehicle is located before performing tours. -1 means that the tour starts from the first TransportPoint and not from a given start depot. 0 is an illegal value, other negative values are reserved for future use, but the behavior is undefined yet.
  • AbstractVehicle.depotIdEnd int The unique key to identify the related end depot clearly (> 0). The end depot is the site where the vehicle is located after performing tours. -1 means that the tour ends at the last TransportPoint and not at a given end depot. 0 is an illegal value, other negative values are reserved for future use, but the behavior is undefined yet.
In xTour2 the properties are within the com.ptvgroup.xserver.xtour.Vehicle:
  • Vehicle.startLocationId String no - 2.1 ID of the vehicle's start location. May be a vehicle location or a site. Opening intervals and service times are not considered for a vehicle's start location. If no start location is specified, it is assumed that the vehicle is available at the first stop.
  • Vehicle.endLocationId String no - 2.1 ID of the vehicle's end location. May be a vehicle location or a site. Opening intervals and service times are not considered for a vehicle's end location. If no end location is specified, it is assumed that the vehicle remains at the last stop.
Feel free to get back to me in case of questions,
