these days a player mentioned that SAP has an issue with the creation of some SOAP request elements. Maybe someone of you has an idea how to deal with this?
The issue is
- Some SOAP elements are defined as OPTIONAL with a boolean type (e.g. constructionStep)
<complexType name="StandardParams"> <complexContent> <extension base="tns:PlanningParams"> <sequence> <element maxOccurs="1" minOccurs="0" name="goalImportance" nillable="true" type="tns:GoalImportance"/> </sequence> <attribute name="availableMachineTime" type="xsd:int" use="optional"/> <attribute name="basicConstructionMethod" type="xsd:string" use="optional"/> <attribute name="constructionStep" type="xsd:boolean" use="optional"/> <attribute name="endSequencingStep" type="xsd:boolean" use="optional"/> <attribute name="improvementMethod" type="xsd:string" use="optional"/> <attribute name="improvementStep" type="xsd:boolean" use="optional"/> <attribute name="maximumNumberOfUnscheduledOrdersToBeAnalyzed" type="xsd:int" use="optional"/> <attribute name="middleSequencingStep" type="xsd:boolean" use="optional"/> <attribute name="sequencingMethod" type="xsd:string" use="optional"/> <attribute name="startSequencingStep" type="xsd:boolean" use="optional"/> <attribute name="tourReductionStep" type="xsd:boolean" use="optional"/> </extension> </complexContent> </complexType> - If the ABAP source mentions the value of the property as "false" it causes the whole element not to be mentioned in the SOAP request which means the server - not being aware of the source of the request - has to treat the value based on a server side configuration.
- The server standard for "constructionStep" when StandardParams are applied is TRUE.
- Can you see the problem? If an ABAP developer wants to override the step by setting the source to false it doesn't cause the proper reaction.
Any help is appreciated!
