while using the PTV xServer .NET and testing the calculateExtendedRoute operation, I have encountered some unusual behavior concerning the restrictions on the route. It seems like some restrictions are not being considered.
I have two examples.
Example 1:
A bridge between the border of Hungary (Komárom) and Slovakia (Komárno). The bridge has two restrictions: max vehicle weight (20t) and max vehicle height (4.3m). If i use the PTV Map&Guide internet with the truck40t_02-00_M truck profile, the calculated route considers the restrictions and creates a path that bypasses the bridge (if I change the parameters GVWR <= 20t and vehicle height <= 4.3m, the calculated route now goes correctly across the bridge).
The problem occurs when I call the calculateExtendedRoute operation with my parameters. If I set the vehicle height to something above 4.3m the bridge height restriction is considered and the calculated route bypasses the bridge, however, if I set the weight to something above 20t, the restriction is not considered and the route still goes over the bridge.
Example XML request:
<?xml version="1.0" encoding="utf-16"?>
<calculateExtendedRouteRequest xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ArrayOfWaypointDesc_1>
<WaypointDesc fuzzyRadius="0" linkType="AUTO_LINKING" xmlns="http://xroute.xserver.ptvag.com">
<wrappedCoords>
<kml xsi:nil="true" />
<point x="18.118686676025391" y="47.742900848388672" />
</Point>
</wrappedCoords>
<nodeID xsi:nil="true" />
<viaType xsi:nil="true" />
</WaypointDesc>
<wrappedCoords>
<point x="18.129201889038086" y="47.762100219726563" />
</Point>
</wrappedCoords>
</WaypointDesc>
</ArrayOfWaypointDesc_1>
<ArrayOfRoutingOption_2>
<RoutingOption parameter="COUNTRY_ENCODING" value="ISO2" xmlns="http://xroute.xserver.ptvag.com" />
<RoutingOption parameter="OPTIMIZATION" value="90" xmlns="http://xroute.xserver.ptvag.com" />
<RoutingOption parameter="SPEED_PROFILE" value="80,55,65,30,55,23,45,20,40,18,30,15,12,7,6,4" xmlns="http://xroute.xserver.ptvag.com" />
</ArrayOfRoutingOption_2>
<ArrayOfExceptionPath_3 xsi:nil="true" />
<ResultListOptions_4 totalRectangle="false" tollManoeuvres="false" texts="false" segments="true" segmentAttributes="false" polygon="true" nodes="false" manoeuvreGroups="false" urbanManoeuvres="false" manoeuvreAttributes="false" dynamicInfo="false" detailLevel="ALL" brunnelManoeuvres="false" boundingRectanglesOffset="0" boundingRectanglesC="0" binaryPathDesc="true" manoeuvres="false">
<cenEmissionConfiguration xsi:nil="true" xmlns="http://xroute.xserver.ptvag.com" />
<destDetail xsi:nil="true" xmlns="http://xroute.xserver.ptvag.com" />
<emissions emissionLevel="BASIC" xmlns="http://xroute.xserver.ptvag.com" />
<hbefaType version="HBEFA_3_2" xmlns="http://xroute.xserver.ptvag.com" />
<startDetail xsi:nil="true" xmlns="http://xroute.xserver.ptvag.com" />
</ResultListOptions_4>
<CountryInfoOptions_5 xmlns:q1="http://xroute.xserver.ptvag.com" xsi:type="q1:CountryInfoVehicleOptions" allEuro="true" calculatePartTollCosts="true" detailedTollCosts="true">
<q1:wrappedReductionIDs xsi:nil="true" />
<q1:wrappedTollScenarios xsi:nil="true" />
<q1:wrappedOptions>
<q1:VehicleOption parameter="TYPE" value="TRL" />
<q1:VehicleOption parameter="LENGTH" value="1875" />
<q1:VehicleOption parameter="WIDTH" value="255" />
<q1:VehicleOption parameter="HEIGHT" value="400" />
<q1:VehicleOption parameter="TOTAL_WEIGHT" value="40000" />
<q1:VehicleOption parameter="TRAILER_WEIGHT" value="15000" />
<q1:VehicleOption parameter="EMPTY_WEIGHT" value="15000" />
<q1:VehicleOption parameter="LOAD_WEIGHT" value="21250" />
<q1:VehicleOption parameter="AXLE_WEIGHT" value="11500" />
<q1:VehicleOption parameter="NUMBER_OF_AXLES" value="5" />
<q1:VehicleOption parameter="CYLINDER_CAPACITY" value="12000" />
<q1:VehicleOption parameter="HEIGHT_ABOVE_FRONT_AXLE" value="400" />
<q1:VehicleOption parameter="EMISSION_CLASS" value="EURO_5" />
<q1:VehicleOption parameter="EMISSION_TECHNOLOGY" value="EGR" />
<q1:VehicleOption parameter="FUEL_TYPE" value="DIESEL" />
<q1:VehicleOption parameter="PARTICLE_FILTER_TYPE" value="NONE" />
</q1:wrappedOptions>
</CountryInfoOptions_5>
<CallerContext_6>
<CallerContextProperty key="CoordFormat" value="OG_GEODECIMAL" />
<CallerContextProperty key="ProfileXMLSnippet" value="<?xml version=\"1.0\" encoding=\"utf-8\"?><Profile xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"><FeatureLayer majorVersion=\"1\" minorVersion=\"0\"><GlobalSettings enableTimeDependency=\"true\" /><Themes><Theme id=\"PTV_TruckAttributes\" enabled=\"true\" priorityLevel=\"0\" /><Theme id=\"PTV_RestrictionZones\" enabled=\"true\" priorityLevel=\"0\" /></Themes></FeatureLayer><Routing majorVersion=\"2\" minorVersion=\"1\"><Course><AdditionalDataRules enabled=\"true\" /></Course></Routing></Profile>" />
</wrappedProperties>
</CallerContext_6>
</calculateExtendedRouteRequest>Example 2:
The road from Podkoren (Slovenia) to Tschau (Austria). The road is blocked for vehicles with a trailer. Once again, when using the PTV Map&Guide the restriction is considered and the calculated route goes around it, but when I call the operation, the restriction is once again not considered and the calculated route goes on the restricted road.
The XML request is basically the same, except for the WaypointDesc:
<wrappedCoords>
<point x="13.756142616271973" y="46.493747711181641" />
</Point>
</wrappedCoords>
</WaypointDesc>
<wrappedCoords>
<point x="13.77748966217041" y="46.547710418701172" />
</Point>
</wrappedCoords>
</WaypointDesc>
</ArrayOfWaypointDesc_1>Any suggestion as to why the differences occur will be greatly appreciated. Thank you again in advance.
Rok
