I need to send to xTour one tour not created by xtour with some transport order.
So I need to create an object kind of inputPlan to send to xTour.
Can you tell me the best way ?
Thank you
tour not created by xTour
Re: tour not created by xTour
Hello Michel,
I need more details to give a proper description. Do you simply want to evaluate whether the given tour violates constraints? Or do you need to improve the quality of the tour?
Of course it is important to separate those usecases from each other because you have to choose the proper planning params class (check http://xserver.ptvgroup.com/forum/viewt ... ?f=6&t=489).
But I really recommend that you describe the users story (without mentioning the xServers) and then Clement or I can tell you what you have to do.
puissancei
The scenario is very simple : I need to use an existing tour to create an optimization.
- I add the tour (not created by xTour).
- I add some independant order.
- The initially added tour can be modified (order, duratin, add order....).
- I ask to xTour to organize this.
I saw the topic but if you can give me your experience return...
Thank you
Thank you
Hello Michel,
sounds like you have to provide
- a set of orders, scheduled ones and unscheduled ones. Let's call the scheduled ones SO1, SO2, SO3, ... and the unscheduled ones UO1, UO2, UO3, ... So the total array of orders is {SO1, SO2, SO3, ..., UO1, UO2, UO3, ...}
- then you need the input plan including the tour based on the scheduled orders: plan.chains[0].tours[0].tourPoints[..] = {SO1,SO2, SO3...}
- the planning class you'd like to use, e.g. StandardParams
puissancei
Thank you Bernd.
Another question about this.
In my test the new order are well added but the why the initial plan is not modified to reorder the tour points if it's better.
see xtour log attachement
- Attachments
- xtour-server.log.xml
- (155.71 KiB) Downloaded 792 times
Hello Michel,
from what I see in your request you deactivated all the sequencing and the improvement steps which might lead to further improvements.
Activate those steps and you get even better results.
puissancei
YES.... of course !!!!!!!!
Thank you
Thank you
