Transit restrictions
krzysiek mbis
Post by krzysiek mbis »
Does routing mechanizm uses transit restrictions by default ?
Is there a way to turn it on/off ?
Best Regards,
Krzysiek
Krzysiek Paziewski
Re: Transit restrictions
Hello Krzysiek,
do you refer to TruckAttributes or PTV_RestrictionZones? As these are feature layers you can enable/activate then on request (default is "feature layers are disabled") or preconfigure them in the profile file in use.
Check this piece of XML:
	<GlobalSettings enableTimeDependency='True'/>
	<Themes>
		<Theme id='PTV_TruckAttributes' enabled='True' priorityLevel='0'/>
		<Theme id='PTV_RestrictionZones' enabled='False' priorityLevel='0'/>
	</Themes>
</FeatureLayer>
You can inject it via SNIPPET or config file.
