Does routing mechanizm uses transit restrictions by default ?
Is there a way to turn it on/off ?
Best Regards,
Krzysiek
Transit restrictions
- krzysiek mbis
Krzysiek Paziewski
Re: Transit restrictions
Hello Krzysiek,
do you refer to TruckAttributes or PTV_RestrictionZones? As these are feature layers you can enable/activate then on request (default is "feature layers are disabled") or preconfigure them in the profile file in use.
Check this piece of XML:
You can inject it via SNIPPET or config file.
<GlobalSettings enableTimeDependency='True'/>
<Themes>
<Theme id='PTV_TruckAttributes' enabled='True' priorityLevel='0'/>
<Theme id='PTV_RestrictionZones' enabled='False' priorityLevel='0'/>
</Themes>
</FeatureLayer>Best regards,
