Result of renderMapBoundingBox, wrappedObjectsField property
PTV Developer Raster Maps API
tswierkot@lis.eu
Post by tswierkot@lis.eu »
Hello together,
I have a problem with renderMapBoundingBox and return type wrappedObjectsField. I think it returns a list of map restriction, but in the type of each description is something like (4 examples):
DIR_OPT_COND_MALUS5|2=240
MAX_HEIGHT|2=250
MAX_HEIGHT|2=400
DIR_OPT_COND_MALUS5|2=160
I know the meaning of the strings from here -> http://xserver.ptvgroup.com/forum/viewt ... p=449#p449
However what is this numbers, something like: "|2=160"? I found here -> http://xserver.ptvgroup.com/forum/viewt ... f692b#p432 but it is not 100% clear for me. So, the first number is something like vehicle property value, and the second is value of it. However, how I can know what is this value? The second question is, for what I need this vehicle property value, when I have already the meaning of value in string before character | (I know the meaning of the strings from the first link)?
The next question is: what is a meaning of "malus"?
Re: Result of renderMapBoundingBox, wrappedObjectsField prop
The description you are getting back is described in the API for the roadeditorlayer class. Have a look at http://xserver.ptvgroup.com/fileadmin/f ... ditorLayer
So to translate your examples:
- The segment is closed for vehicles heavier than a 2400 kg except for residential for both driving direction
- The segment is closed for vehicles with a height larger then 250 cm for both driving directions
- The segment is closed for vehicles with a height larger then 400 cm for both driving directions
- The segment is closed for vehicles heavier than a 1600 kg except for residential for both driving direction
thanks for your answer, Joost.
One more statement about MALUS values: as this is a term that affects routing I recommend to start a thread in xRoute if necessary. But before you create a new post please check this message: http://xserver.ptvgroup.com/forum/viewt ... alus#p1306
Maybe it helps,
regards Bernd
tswierkot@lis.eu
Ok, thanks for replies.
I have additional question, about FeatureLayer:
In request there is name = "PTV_TruckAttributes", example replies (it is result.LayerObject[].Object.descr):
"driveType=0|maxWeight=7500|freeForDelivery=1"
"driveType=0|maxHeight=400"
"loadType=1|driveType=0|freeForDelivery=1|opening=0"
Where I can find the meaning of each value? Some are clear (maxHeight), but some not (loadType, driveType etc).
the properties documantation is available here:
http://xserver.ptvgroup.com/fileadmin/f ... t=loadType
Is this info sufficient?
tswierkot@lis.eu
Yes, it is ok. For now I try to parse this description string to get all properties, is there better way to get all properties? Something like PTV object with it?
No, none that I know of.
And it is quite generic, i.e. this parsing approach refers to TruckAttributes.
Other data - other parsing.
tswierkot@lis.eu
And how about "PTV_TrafficIncidents" FeatureLayer, there is a example result:
"absoluteSpeed=40|category=61|language=en|message=A49 southwestern at Kassel left lane closed|length=1428|startX=4380690|startY=5547109|language=|incidentId=TTI-1a4962c4-0c5f-4be8-98dd-0e5c3d768f51-TTR121843417011584-2_1"
what is exactly the "startX=4380690|startY=5547109", and how to get the coordinates from it (the best for me is just to get latitude, and longitude)?
I see it here:
http://xserver.ptvgroup.com/fileadmin/files/PTV-COMPONENTS/DeveloperZone/Documents/xServer_public/manual/Default.htm#FeatureLayerContent-Documentation/featurelayercontent.html#PTV_TrafficIncidents%3FTocPath%3DTechnical%2520Concepts%7CAbout%2520Feature%2520Layer%7CLayer-Specific%2520Properties%7C_____5
however there no explanation in it.
As the string returned as "objectInfo" is rendered at feature layer design time (on data center) we do not know whether you requested the map tile in OG_GEODECIMAL or PTV_MERCATOR or whatever: It is simply stored in PTV_SMARTUNITS.
But:
If your mapping interface works with OG_GEODECIMAL you can have a look at the ObjectInfos X,Y-Coordinate property:
comparison between different coord formats
