Hi!
where can I enable in the config, that my Address will use Country IsoCodes2 by default ?!
Peter
Country IsoCodes 2 by default
Re: Country IsoCodes 2 by default
There is a SearchParameter COUNTRY_CODETYPE the default value is =3 (country code plate). So you can set this parameter to value =1 (ISO2) or =6 (Unknown). If Unknown is set, then all formats are considered as possible input formats and CountryCodePlate is used as the output format.
Jochen Anderer
Manager Engineer
PTV GROUP GERMANY
Manager Engineer
PTV GROUP GERMANY
the parameter mentioned by Jochen is available in the xlocate-default.properties in the /conf. You could also change it in the native-default.xml. Just take care of the priorities of the resources. Here are some screenshots. If you access the AZURE platform you need to set parameters in the request because you can't reconfigure our server defaults.
peter.detzner
Great! Helped me a lot! Thanks for the fast response!!
