Error - findAddresses() functionality is not supported...
Karol.Korol
Post by Karol.Korol »
Recently, after returning from vacation, I tested my findAddresses web API. Before making any changes to the API, I wanted to make sure everything was working properly. It turned out that it worked before but now server returned an error:
ErrocKey: 1002
ErrorMessage: findAddresses() functionality is not supported by this server
ClassName: com.ptvag.xserver.xlocate.XLocateException
Of course, the first thing I did, was ask the co-workers if something was changed at PTV - everyone said they did not change anything (somehow I do not believe it).
Thank you in advance for your help.
Karol Korol
.NET Developer
karol.korol@4ls.pl
4LS sp. z o.o.
Złotniki, ul.Obornicka 52
62-002 Suchy Las, PL
http://www.4ls.pl
Re: Error - findAddresses() functionality is not supported..
Hello Karol,
as this is a standard support issue I beg you to create a ticket via standard support.
Please check your license: the error mentioned in the post occurs e.g. if the license.ptv doesn't enable batch processing.
Another potential cause to be checked (but probably not this time): is geocoding in general supported? (xlocate.mode=7 enables 1+2+4)
  • 1 = geocoding
  • 2 = reverse geocoding
  • 4 = poi search
Those values have to be checked with a bitwise OR.
Did you also use the batch version of findAddress before your holiday?
xlocate.batch=true enables batch processing
