Setting rules for break times
frank.essenberger
Post by frank.essenberger »
Hello everybody,
in our current project we would like to include break times in the planning of the tour. With break times we mean a rule set like this:
On Monday make a break of 30 Minutes sometime between 12:00 and 13:00 (flexible break)
On Tuesday no break
On Wednesday make a break of 60 Minutes between 13:00 and 14:00 (fixed break)
Is it possible to create rules like this?
Frank Essenberger
Re: Setting rules for break times
Hello Frank,
the required usecase is almost possible - we provide some approaches but let's say "we match 90%".
Take a look at the DriverRegulations , DriverSettings and the BreakIntervals.
By using the DriverRegulations in combination with BreakIntervals you can specify that the driver should take a break of a given length (e.g. 50 minutes, the length applies to ALL GIVEN INTERVALS - this is where we loose the final 10%) on MON, WED,FRI between 11:00 and 13:00.
With the DriverSettings you have to activate these rules for a specific Vehicle.
Here's an example:
<RegulationsBase xsi:type="DriverRegulations" id="1" beginningOfCalendarWeek="0">
	<breakIntervals breakPeriod="3000"><!-- 0:50 minutes each break /-->
		<wrappedIntervals>
			<Interval from="39600" till="46800" /><!-- Monday 11:00 - 13:00 /-->
			<Interval from="126000" till="133200" /><!-- Tuesday 11:00 - 13:00 /-->
			<Interval from="212400" till="219600" /><!-- and so on /-->
			<Interval from="298800" till="306000" />
			<Interval from="385200" till="392400" />
		</wrappedIntervals>
	</breakIntervals>
	<breakRule xsi:nil="true" />
	<dailyRestRule xsi:nil="true" />
	<weeklyRestRule xsi:nil="true" />
	<workingRule xsi:nil="true" />
</RegulationsBase>
and for the vehicle:
<Vehicle_3 ..] id="1" [..]>
	<wrappedOperatingIntervals xmlns="http://xtour.xserver.ptvag.com">
		<Interval from="25200" till="61200" /><!-- MONDAY 07:00 - 17:00 /-->
		<Interval from="111600" till="147600" /><!-- TUESDAY 07:00 - 17:00 /-->
		<Interval from="198000" till="234000" />
		<Interval from="284400" till="320400" />
		<Interval from="370800" till="406800" />
	</wrappedOperatingIntervals>
	<driverSettings breakRuleActive="false" dailyRestRuleActive="false" regulationsId="1"
remainingPeriods="" weeklyRestRuleActive="false" workingRuleActive="false"
		<maximumTourPeriodRestriction xsi:nil="true" />
	</driverSettings>
</Vehicle_3>
Here is the result
As you can see in the grid the server places an optimal 0:50 minutes break within each operating interval.
Looks great, doesn't it?
i.kobeissy
Post by i.kobeissy »
Is it possible to force multiple breaks using the breakIntervals ?
Hello Ibrahim,
In xTour1? Yes, but they have to have equal length...
A 30min break between 10:00 and 11:00 and another30min break between 15:00 and 16:00 is possible.
But a 30min break between 10:00 and 11:00 and a 45min break between 15:00 and 16:0 is not possible.
Best regards from Germany,
i.kobeissy
Yes we're using xTour1. Thanks for your answer
Let me just add some info in the context of xTour2:
In this API we invented a more flexible approach of breaks:
  • com.ptvgroup.xserver.xtour.Driver describes the driver and his given constraints such as operating intervals but also an optional set of BreakIntervals
  • com.ptvgroup.xserver.xtour.BreakInterval - now these intervals can specify individual "periods", so you could ask for a 15min coffee break between 09:00 and 09:30 in combination with a 45min break between 11:45 and 13:15.
  • I am aware of players who use this approach to compensate some gaps in the features such as
    • Fake overnight week tours: operating interval: [MON/08:00 - FRI/17:00] plus various break intervals such as [MON/18:00-TUE/08:00, 14hours]...
    • Appointments without a given location
clvo
Post by clvo »
the way I see it, the option in the Sequence Optimization API is unfortunately no longer available - or am I missing something?
Thank you very much!
LG Claus
Hello Claus,
you are right: the Sequence Optimization API does not cover 100% of the underlying xTour2 options when it comes to breaks of a Driver:
  • operating Intervals : supported, but limited to a single interval
  • breakIntervals : not supported
  • configurableWorkingHours : supported partially (e.g. breakRuke)
  • configurableWorkingHoursPreset : supported partially (not all presets)
  • workLogbookSummary : supported
