Our customers are asking about such a route calculation, that the map takes into account mountains, highlands and so on up to calculate the chepest route having in mind besides milage and toll costs also cost of fuel.
Krzysztof from PTV suggest us to use (http://xserver.ptvgroup.com/fileadmin/f ... =elevation, we checked it out and the only thinkg looks similiar is cenEmissions.actualFuelConsumption. Is it proper solution – how should we use it, what version cover that function, how it works in details and so on?
Routing calculation with taking into account fuel costs
Re: Routing calculation with taking into account fuel costs
Hello guys,
we have to separate the following topics from each other:
I know that this answer is negative but it is simply realistic.
Can I help anyway?
- Is it possible to parametrize a routing so it considers the consumption of fuel and the elevantions in determining the proper geometry of a route? From my opinion this is not possible. I recently posted some info about the meaning of COSTS in the article Interpretation of speed table. In other words: we consider driving time and distance, add malus values on individual segments (ExceptionPath) or segment categories (e.g. AVOID_HIGHWAYS) and ensure that forbidden segments are not used (e.g. TruckAttributes). But the segment costs are not based on fuel consumption, emissions or elevation info.
- Return various output details such as ELEVATION info and emissions (incl. FUEL). But this optional info is simply calculated by applying specific algorithms to the data (height information) considering various standard such as CEN, COPERT, HBEFA3.1...
Can I help anyway?
Thank you for the answer - are you going and when to use such a parameter to optimize teh route or at least calculate fuel costs for exact route?
Best regards Przemek
Hello Przemek,
I'll forward these questions to product management as they are strategic
Hello Przemek,
long time ago... here's some info that refers to your original post: within xServer 2 we offer so called Monetary Cost Optimization.
Compared to the traditional routing you can now specify costs/distance and costs/time and further factors. Together with toll costs we will then determine the path that minimizes the total costs of a track. This is an important new approach because In the past we determined the path first and computed the toll costs afterwards. Be aware that the pie charts in the following screenshots display costs relative to the total costs.
