Geodatasource layer based on MS Access?
Hello community,
in the recent weeks several contacts asked me how to migrate the Access based geodatasource layers from old xServers (32bit) to state-of-the-art servers (1.18). The answer is simple:
MS Access is no longer supported!
As it is mentioned on the Developer Zone the following databases are supported by now:
  • Oracle ojdbc<version>.jar
  • IBM DB2 db2jcc.jar
  • Microsoft SQL Server jtds-<version>.jar
  • MySQL mysql-connector-java-<version>-bin.jar
  • SQLite sqlitejdbc-<version>.jar
  • Apache Derby (bundled) derbyclient-<version>.jar
So you have to migrate your data from Access to one of these containers and then reconfigure your server's geodatasource files.
Just a little snippet:
my local installation is based on a MS SQL SERVER and is running fine with the following database connection style:
<Datasource driver="sun.jdbc.odbc.JdbcOdbcDriver" url="jdbc:sqlserver://localhost:1433;databaseName=MyDatabasename" user="MySQLServerUsername" password="MySQLServerPassword" />
As long as the structure of your data didn't change this should be the only action that is required.
The application itself should run without any changes (no guarantee ;-) )
