PTV xServer 1.26.0.0. available
Check the Download Area (login required) to get the latest version.
Highlights:
  • General: Sending requests to dedicated backend instances for detailed monitoring
  • xMap: Improved visualization of borders and ferry lines
  • xRoute: More stability in updating traffic incidents
  • xMapmatch: Great improvement in performance and quality
  • xTour: Switchable product incompatibilities per vehicle
And here are the release notes:
Release Notes PTV xServer 1.26
PTV xCluster Server 1.26.0.0
  • Improvement: Added new attribute 'dataCompatibilityVersion' to the stored profiles in order to check consistency and validity with new PTV map data version. Please ensure that your profiles and map data have the same version as otherwise the PTV xCluster won't start (see 'Technical Concepts - About Profiles - Profile & Map Versions').
  • Improvement: When validating profiles against their schemas, http URLs to localhost are not allowed anymore. Please use a filename instead (see 'Technical Concepts - About Profiles').
  • Improvement: For detailed monitoring it is now possible to send requests to dedicated backend instances.
  • Improvement: Updated the Java server runtime to JRE 1.8.0_162.
  • Improvement: Updated Apache Tomcat to version 8.5.27.
  • Improvement: Updated Apache CXF to version 2.6.17.
  • Improvement: In case a module is going down or stopped, more information is logged.
  • Bugfix: For all exceptions the type and message are logged in any case.
PTV xDima Server 1.26.0.0
  • Improvement: Added new attribute 'dataCompatibilityVersion' to the stored profiles in order to check consistency and validity with new PTV map data version. Please ensure that your profiles and map data have the same version as otherwise the PTV xDima won't start (see 'Technical Concepts - About Profiles - Profile & Map Versions').
PTV xLoad Server 1.26.0.0
PTV xLocate Server 1.26.0.0
PTV xMap Server 1.26.0.0
  • Improvement: The font Noto Sans instead of Liberation Sans is now delivered with the PTV xMap as it has more glyphs. The default in the rendering profiles is further on Arial and usually used on Windows, but on Linux the new font is used.
  • Improvement: The visualization of federal borders in the rendering profiles 'silkysand', 'sandbox' and 'gravelpit' is improved.
  • Improvement: The visualization of ferry lines in the rendering profiles 'silkysand' and 'sandbox' is improved.
  • Improvement: The visualization of disputed borders in future maps is prepared.
  • Improvement: By restricting the loaded Feature Layer data to the licensed themes, the memory usage is reduced.
  • Improvement: Reduced the work load for very frequent updates of new Feature Layer 'PTV_TrafficIncidents'.
  • Improvement: Errors caused by unavailable Feature Layer 'PTV_TrafficIncidents' have clearer messages.
  • Bugfix: Fixed a race condition to get a synchronized and stable startup.
PTV xMapmatch Server 1.26.0.0
  • Improvement: The performance especially for sparse tracks is improved (see new attributes 'astarEnabled' and 'astarFactor' in the profiles 'default' and 'sparse-signal' and optimized values in the profile 'sparse-signal').
  • Improvement: The performance using local matching is improved by implementing an optimized map access.
  • Improvement: The attribute 'maximumNumberOfCandidates' in the profiles to balance result quality and performance is now implemented.
PTV xRoute Server 1.26.0.0
  • Improvement: Added new attribute 'dataCompatibilityVersion' to the stored profiles in order to check consistency and validity with new PTV map data version. Please ensure that your profiles and map data have the same version as otherwise the PTV xRoute won't start (see 'Technical Concepts - About Profiles - Profile & Map Versions').
  • Bugfix: Due to WSDL compatibility the response attribute 'manoeuvreType' is always generated, if detailed toll costs are enabled. The request attribute 'tollManoeuvres' is therefore deprecated.
  • Bugfix: A Feature Layer instead of a Road Editor violation is correctly identified and returned.
  • Bugfix: The toll prices that depend on trailer weight or axle load are considered properly, when these parameters are set to 0 in the profile.
  • Bugfix: In special cases using Feature Layer 'PTV_GeneralTruckRestrictions' the dynamic travel time could not be calculated.
  • Bugfix: The height interpolation of points is fixed, that were missed in the response elevation profile.
PTV xTerritory Server 1.26.0.0
  • Improvement: Added new attribute 'dataCompatibilityVersion' to the stored profiles in order to check consistency and validity with new PTV map data version. Please ensure that your profiles and map data have the same version as otherwise the PTV xTerritory won't start (see 'Technical Concepts - About Profiles - Profile & Map Versions').
PTV xTour Server 1.26.0.0
  • Feature: The consideration of product incompatibilities can be switched off for specific vehicles by using the new attribute 'ignoreProductIncompatibilities'.
  • Improvement: In case of using the tour reduction step it is now possible that there are new tours because of unscheduled orders during the improvement step.
  • Improvement: Added new attribute 'dataCompatibilityVersion' to the stored profiles in order to check consistency and validity with new PTV map data version. Please ensure that your profiles and map data have the same version as otherwise the PTV xTour won't start (see 'Technical Concepts - About Profiles - Profile & Map Versions').
PTV xServer bundle 1.26.0.0
  • Includes: PTV xCluster Server 1.26.0.0
  • Includes: PTV xDima Server 1.26.0.0
  • Includes: PTV xLoad Server 1.26.0.0
  • Includes: PTV xLocate Server 1.26.0.0
  • Includes: PTV xMap Server 1.26.0.0
  • Includes: PTV xMapmatch 1.26.0.0
  • Includes: PTV xRoute Server 1.26.0.0
  • Includes: PTV xTerritory Server 1.26.0.0
  • Includes: PTV xTour Server 1.26.0.0
  • Includes: PTV xServer add-on AJAX Maps 3.5.25.0
  • Includes: Code Sample Browser 1.26.0.0
