Test of HERE Satellite images (via PTV)
PTV Developer Raster Maps API
as some of you already know PTV is a broker of HERE satellite images. What you should know about that topic from a proccess perspective is:
  • You can get a license for those maps via PTV if you use them in combination with PTV xServers.
  • You need a so-called APP_ID and an APP_TOKEN to test and go live with those satellite images.
  • We can provide a TEST ID and TOKEN for a 90 days trial (the test phase can't be prolonged because of technical reasons).
  • Get in touch with your sales counterpart to get it.
  • If needed you can find various integration samples in the forum.
In short terms: Once you managed to consumer the satellite images via HERE and the tokens you can combine them as separate layer within your web application.
Re: Test of HERE Satellite images (via PTV)
Just learned that HERE has changed the Authentication Method.
Therefore please consider this article: https://xserver.ptvgroup.com/forum/view ... =56&t=1636
Good moment to switch to PTV Developer Maps API!
