Delay Cluster effect on WpfMap
PaulBuechs
Post by PaulBuechs »
We are facing some issues during clustering our objects on WpfMap. On DemoCenter Code we find following line:
var clusterer = new TileBasedPointClusterer<Post>(MapView.LogicalSize, 0, 19);
In the moment the cluster effect starts rather early and we would like to have it in a way, that it’s start after a given zoom level. At least don’t cluster so ‘early’.
Question:
What does the parameters mean?
Is it possible to start clustering at given zoom level, during parameters?
Kind regards,
Paul
Re: Delay Cluster effect on WpfMap
From the metadata in visual studio:
        // Summary:
        //     Initializes a new instance of the Ptv.XServer.Controls.Map.Tools.TileBasedPointClusterer`1
        //     class.
        // Parameters:
        //   referenceSize:
        //     The logical size of the cluster area.
        //   minLevel:
        //     The minimum level for which clusters should be created.
        //   maxLevel:
        //     The maximum level for which clusters should be created.
        public TileBasedPointClusterer(double referenceSize, int minLevel, int maxLevel);
A bit of trial and error:
From most zoomed int (level 19) until maxLevel the cluster will be caculated based maxLevel zoom
From maxLevel to minLlevel the cluster will be caculated based the actual zoom
From minLlevel until max zoomed out (level 0) the cluster will be caculated based minLlevel zoom
i hope this helps
