XMAP Server 18.1 // [config.town.symbols]
Posted: Thu Oct 09, 2014 8:41 am
by Fuema
We started today using XSERVER 1.18.1.0.
We used to display the city codes in the map.
in the former version wie used this ini file roadattribues.ini, where we added following section
showpostcode=true
we´re using the default profile and we edited all ini files and we created the render.ini - unfortunately this didn´t work out.
do we have do add something else?
any ideas / tips?
thx
Re: XMAP Server 18.1 // [config.town.symbols]
Posted: Thu Oct 09, 2014 9:28 am
Hello Fuema,
this feature also works in the latest version. I guess the cause for the trouble is the missing link between the used request profile (
xmap-default.properties or the profile requested by the CallerContext):
within the properties file there is a key=value that refers to the INI-File. By default this value is empty in the xmap-default.properties:
# The map profile contains visualization parameters such as colors etc.
# If empty the engine's default is used
map.profile=
Let's compare it with the
xmap-combinedtransports.properties file:
map.profile=combinedtransports.ini
And this ini-file has to contain the switch that enables the visualization of the zip codes.
- Postcode visualization enabled
But: another potential cause is the scale as you can see on the following image:
- postcodes invisible due to scale
The town label does not represent a postcode area but the whole town!
Quite sure that this helps,
Posted: Thu Oct 09, 2014 10:56 am
by Fuema
Thank you Bernd ! it was the missing link in the default.properties !
do you have an best practice to set in such ini files?
thx
Posted: Thu Oct 09, 2014 12:58 pm
What do you mean by "practice to set in such ini files"?
Posted: Tue Jan 05, 2016 11:25 am
by Fuema
wow ... i just seted up a the new xserver 20.1.3 and i came to this thread again
Sorry for the really long delay ... i meant do you have a basic installation or guide how to set up the xserver for a haulier with a 40t fast truck?
bye
markus
Posted: Tue Jan 05, 2016 12:29 pm
Hello Markus,
sounds more like an xRoute question, isn't it
Please check
http://127.0.0.1:50030/pages/configurator.html on the running xRouteServer.
Look at the
profiles:
This page should display several available reference profiles:
- Reference profiles, e.g. "truck40t_01-00_M"
To activate such a profile use the CallerContext / CallerContextProfile with key="Profile".
PS: "A proper stack is the soul of the match." - old pool wisdom
