I don't understand why this.XMapStyle = "Gravelpit" (or other value) has no effect.
Xserver 1.22
Xserver .net 1.5
Thank you
XMapStyle
Re: XMapStyle
Hello Michel,
I forwarded your topic to Oliver, usually he answers quite fast.
As a temporary workaround I can offer this:
Change the default profile on the server which means you set the map.profile (and restart the xMap afterwards)
in the conf files# The map profile contains visualization parameters such as colors etc.
# If empty the engine's default is used
#map.profile=
map.profile=gravelpit.ini
- xmap-ajax-av.properties
- xmap-ajax-fg.properties
- xmap-ajax-bg.properties
- xmap-ajax-ov.properties
- Oliver Heilig
Re: XMapStyle
Hi Michel,
the XMapStyle must be an appropriate style with an -fg and -bg profile. What should work out-of-the box is
default, silkysand, sandbox and gravelpit
I've tested the sample "FormsMapVB" at
https://github.com/ptv-logistics/xservernet-bin
to change the style at runtime, and it works as expected:
Can you reproduce this?
Oli
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
FormsMap1.XMapStyle = "gravelpit"
End Sub
Oli
