we have a use case where we need to include a TransportOrder in an existing tour, we're trying to use inputPlan,
we have one tour with one transport order and we are trying to add another transport order, we're using TransportAB,
the response of PTV doesn't include any violation, the UnscheduledOrderAnalysisResult of the response indicates the status FEASIBLE but the order is not included in the chain, also in the request we have 2 vehicles so if the unplanified order couldn't be added to the existing chain why it's not being added to the other vehicle
we also tried to remove tourSection without luck
can anyone point us please to what/where we're doing anything wrong ?
Many thanks in advance
planBasicTour with inputPlan (XSERS-923)
i.kobeissy
- Attachments
- response.xml
- Response
- (11.02 KiB) Downloaded 627 times
- request.xml
- Request
- (10.72 KiB) Downloaded 589 times
Reason: XSERS-923 has been created
Re: planBasicTour with inputPlan
Hello Ibrahim,
from what I saw in your request the depot of the vehicle doesn't match the tour:
Though the coordinates of the depots 71, 74 and 4 are equal the structure of the input plan seems to prevent us from a proper planning call.
Is there a specific reason why you provided the same depot coords via 3 objects?
<ns7:Vehicle ignoreIntermediatePeriodBeforeFirstTour="false" id="25"
toursMustFitIntoSingleOperatingInterval="true" isPreloaded="false"
ignoreTransportPointServicePeriod="true" drivingPeriodFactor="0.8"
dimaId="1" depotIdStart="4" depotIdEnd="4">Code: Select all
<ns7:Chain vehicleId="25">
<ns7:wrappedTours>
<ns7:Tour vehicleFixed="true" tourPointFixation="NONE" ignoreIntermediatePeriodOfPreviousTour="false" id="1" startTimeFixed="false">
<ns7:wrappedTourPoints>
<ns7:TourPoint tourFixed="false" remainPlanned="false" type="DEPOT" id="71"/>
<ns7:TourPoint tourFixed="false" remainPlanned="false" type="TRANSPORT_POINT" id="72"/>
<ns7:TourPoint tourFixed="false" remainPlanned="false" type="TRANSPORT_POINT" id="73"/>
<ns7:TourPoint tourFixed="false" remainPlanned="false" type="DEPOT" id="74"/>
</ns7:wrappedTourPoints>
</ns7:Tour>
</ns7:wrappedTours>
</ns7:Chain>Is there a specific reason why you provided the same depot coords via 3 objects?
i.kobeissy
Re: planBasicTour with inputPlan (XSERS-923)
Thanks a lot Bernd, Eagle Eye !!!
it's working now
it's working now
Anyway, I created a task and assigned it to DEV for a more deetailed analysis
