for those of you who create their own searchgraphs to be used in xDima's or xTour's distance matrix computation:
Sometimes the creation of the searchgraphs is a bit challenging and the default configuration of the RoutingNetworkGenerator doesn't produce a speaking logfile.
There is indeed one possibility to activate more logging: Use in the file _RoutingNetworkGenerator.ini_template_ the entry _LogFileName_. Then you get after each calculation an additional log file with the milliseconds of each phase.
That's all for now,
best regards
How to activate logging for RoutingNetworkGenerator...
