Restrictions editor
krzysiek mbis
Restrictions editor
Post by krzysiek mbis »
Is there a way to edit restrictions on map?
Usage examples:
I. User wants to delete some specific restriction. Because It is no longer on the road but map still has it.
II. User wants to add some specific restriction. Because map doesn't have it yet but road has it at the moment.
Best Regards,
Krzysiek.
Krzysiek Paziewski
Re: Restrictions editor
Hello Krzysiek,
take a look at the ROAD EDITOR in MAP&GUIDE. This is a frontend which enables you to change segment attributes auch as
  • blocked for cars
  • blocked for hazardous goods
  • blocked for vehicles exceeding specific weight, height, length...
https://xserver.ptvgroup.com/forum/view ... ?f=7&t=376
As this topic is quite a large one and touches many technical constraints you should get in touch with your technical consultant 1:1.
