For a client I'm looking to override these two parameters from xRoute as a default value for xRoute.
So when the request comes in it can override these, but I would like to change this default to
1.4.19 RoutingParameter
AVOID_TOLLROADS value -99
OPTIMIZATION value 70
The API guide says
Describes all possible RoutingParameters. All parameters must not occur more than once, otherwise it is not defined which occurrence will be considered. Only those parameters marked with (*) may be used within a waypoint. All these parameters shall preferably also be set through the XML profile.
Where is the link between the xRoute server settings/module settings to the XML profile?
Does it take a default.xml profile from /conf/profile if there is none?
xRoute default parameters
Re: xRoute default parameters
Found it by raising a ticket. In case anyone else interested:
The corresponding new parameters for
are:
<Course distanceTimeWeighting="70">
<Toll tollMalus="-99" />
</Course>
are:
</Course>
Check this out:
http://xserver.ptvgroup.com/forum/viewt ... file#p1000
describes both the prio and the matching of the OLD2NEW parameters!
