Looking for solution to display active region in Map center
Posted: Fri Jul 28, 2017 6:58 am
- We have the list of Points (i.e. X and Y coordinates) and Geometry data with respect to list of zip codes.
- Based on result of Geometry data; we have added BaseLayer in the map using the tile renderer which is implemented from ITiledProvider interface (Ptv.XServer.Controls.Map.Layers.Tiled).
- We have set the map control envelope using the list of Points (i.e. X and Y coordinates).
Issue:
Active region is displayed in the center of the map as expected but some part of the region is still out side the map.
Find "ActiveRegionActualResult.png" which shows the current display of Map
Find "ActiveRegionExcpectedResult.png" which we want to display the Map in our App
Solutions tried:
We tried to decrease the zoom level of map programmatically as mentioned below, but its not working.
Option 1:
Option 2:
wpfMap.SetEnvelope(new MapRectangle(pointList), "OG_GEODECIMAL");
-- wpfMap: ptv wpf map control.
-- pointList: list of Points (i.e. X and Y coordinates).
-- "OG_GEODECIMAL": Point format
Solutions tried:
Option 1:
ptvMap.Zoom = ptvMap.Zoom - 1;Code: Select all
ptvMap.ZoomLevel = ptvMap.ZoomLevel - 1;
