a customer is using xServer.Net and via a reverse geocode has the XYN geometry of the segments returned by the findLocation method. Unfortunately is not possible to use a GeometryLayer in xServer.Net so the best thing to do is to use Shape Layer. The question is: how may I use LINESTRINGXYN geometry to draw segments in a Shape Layer? Is it possible to have a code fragment?
Thanks in advance,
Giovanni
Segments drawn on map
- Oliver Heilig
Re: Segments drawn on map
Hi Giovanni,
it is possible to add an xServer.NET Layer which internally invokes xMap-Requests with a Custom Layer. I've added a sample "XYNSegments" to
https://github.com/ptv-logistics/xservernet-bin
Oli
Oli
Hi Oliver,
thanks for the example it's what we need!
Just a question: is it possible to use some GeometryOption to play with segment transparency?
Giovanni.
Giovanni.
- Oliver Heilig
Hello Giovanni,
i don't think this is possible, xMapServer1 doesn't support real alpha blending. But you can set the opacity of the XYNLayer.
Oli
Oli
Hi Oliver,
Thanks you so much.
Giovanni.
Thanks you so much.
Giovanni.
