Installing Feature Layer / Changed Request
Posted: Thu May 18, 2017 2:40 pm
by nemec
i am trying to use a Featurelayer in a Ajax Maps script
manager.addPOICategory("featurelayer", "PTV_TrafficIncidents");
It seems, that Feature Layers are not installed.
i have found xserver\webapps\WMS\WEB-INF\lib\FeatureLayerThemes-1.20.0.jar
I think that a special installation routine is necessary ?
Thanks in advance for help
Andreas Nemec
Re: Installing Feature Layer / Changed Request
Posted: Mon May 22, 2017 10:22 am
by nemec
i must change my request, because i am not sure if its an problem of feauture layer
or the problem using Ajax Maps
i will open a new task at the section for ajax maps
Posted: Wed Jun 07, 2017 7:48 am
Hello Andreas,
the feature layer PTV_TrafficIncidents isn't configured by default. You have to install the CONTENT UPDATE SERVICE first.
Have you done this?
http://xserver.ptvgroup.com/fileadmin/f ... %7C_____11
Once this is done the AJAX tutorial should work fine.
Posted: Mon Jun 12, 2017 7:40 am
by nemec
Thank you it is solved.... forgot to write here
