i am trying to use a Featurelayer in a Ajax Maps script
manager.addPOICategory("featurelayer", "PTV_TrafficIncidents");
It seems, that Feature Layers are not installed.
i have found xserver\webapps\WMS\WEB-INF\lib\FeatureLayerThemes-1.20.0.jar
I think that a special installation routine is necessary ?
Thanks in advance for help
Andreas Nemec
Installing Feature Layer / Changed Request
Re: Installing Feature Layer / Changed Request
i must change my request, because i am not sure if its an problem of feauture layer
or the problem using Ajax Maps
i will open a new task at the section for ajax maps
Hello Andreas,
the feature layer PTV_TrafficIncidents isn't configured by default. You have to install the CONTENT UPDATE SERVICE first.
Have you done this?
http://xserver.ptvgroup.com/fileadmin/f ... %7C_____11
Once this is done the AJAX tutorial should work fine.
Have you done this?
Thank you it is solved.... forgot to write here
